Like Tree2991Likes
1/12 forum
Old 03-03-2004 | 10:25 AM
  #7006
fast-ho-cars's Avatar
Default HPI conversion kit
anyone tried the HPI conv for the 12L / Yok stlye cars?
fast-ho-cars is offline
Old 03-03-2004 | 10:34 AM
  #7007
dr_hfuhuhurr's Avatar
got a link?
dr_hfuhuhurr is online now
Old 03-03-2004 | 03:40 PM
  #7008
sean's Avatar
Cats do not like r/c cars.just an observation
sean is offline
Old 03-03-2004 | 07:13 PM
  #7009
lastplace's Avatar
taken from a post the first page:
Tires.. I ran purple fronts size 1.73 I ran pink rears size 1.90 I also used paragon for 15 mins on the tires wiped them off then applied coppertone 45 sun tan lotion until the heat before i was up then wiped dry and much as possible...
Hope this helps you guys
Mike Blackstock
I have to ask, what's the deal with Coppertone SPF 45 after the Paragon?
lastplace is offline
Old 03-03-2004 | 07:16 PM
  #7010
Mike D's Avatar
Originally posted by rayhuang
DavidL and MikeD-some questions for you guys.
I ran a Rug Rat (first T-bar car in 3 or 4 years) and its so different than my Speedmerchant rev3's that I am a bit lost on set-ups. I am used to the quicness in steering feel and on-power / exit steering of the Rev3. What are some of the general changes to be made on the Rat for more steering in general? But-not making it edgy. I hate edgy feeling 12th scales.
Thanks,
Ray
Ray - It sounds like the Gate traction has been a little different lately... The following is where I would start on setup for stock:
Irs front end (10 degree reactive angle, all caster shims foward, .020 springs, 1.5 degrees camber, trinity red stuff lube on king pins), silva spring steel medium-stiff t-plate with 3 pod screws, silva center shock with 40 wt and blue associated spring, tweak screws and no springs on damper tubes, 10,000 Associated silicone in damper tubes, batteries in rear position, 3.5mm ride height, Jaco Grey rears (@ 1.85") and Jaco purple fronts (@ 1.71"), full front and rear compound. I run the servo flat on the chassis with mid-height ball studs on the steering blocks and kimbrough mid-size servo saver. Steering lock at about 4 foot turning circle.
The first changes I would try to the above setup are .075 t-bar and silver center spring. I like the steering of a lot of caster on low traction tracks. A lot of caster cause problems on high traction tracks. I agree with you on car feel - I try to make it steer as much as possible without getting edgy. I hit everything in sight if my car is too aggressive.
Mike D is offline
Old 03-03-2004 | 07:20 PM
  #7011
rayhuang's Avatar
Mike-thats a lot of info to process-hahaha!! Thanks!! See ya in a few weeks!!
Ray
rayhuang is offline
Old 03-03-2004 | 08:29 PM
  #7012
AdR|aN's Avatar
Can someone recommend what kind of ratio for a 10t, 15t and a stock 23t motor??
I am running a CRC v3.1
AdR|aN is offline
Old 03-04-2004 | 05:57 AM
  #7013
Default Notchy diff
Last night I was re-building my diff with the new ceramic balls I got. Cleaned everything, sanded the diff rings then polished them, lightly lubed the diff balls then put everything back together. Now the diff has a very notchy feel to it. I tore it back apart and put in a new set of steel diff balls. Same thing. tried different bearings, different spurs, different axles (one new CRC big ring diff even), everything and is still feels the same.
Any thoughts?
Blake
Old 03-04-2004 | 06:16 AM
  #7014
Default Notchy Diff
When I rebuild a diff, I take some time and "sneak-up" on the right tension. What I mean is, as I put it together, and start to tighten the diff nut, right when it makes the diff come together, I start turning the wheels making the diff operate. (tires move in opposite direction) I'll do this for about 30-seconds to a minute. Then I'll tighten it up a little more, turn the wheels again. I keep doing thiss till I have what I think is the right amount of pressure on the diff. I was "TOLD" that it's possible to "dent" the diff balls or the diff rings if you just tighten the diff all the way all at once. Weather that is true or not, I don't know, but my diffs go together pretty smooth. Hope this helps.
acyrier is offline
Old 03-04-2004 | 06:21 AM
  #7015
Would it be possible to dent the ceramic balls? I've re-sanded the faces of the diff plates twice now? Nothing visible there, diff balls look fine as well.
Old 03-04-2004 | 06:25 AM
  #7016
Default notchy diff
blake,
it could be the thrust washers and balls. i have seen them wear out before the main balls/washers
mike lindsay(non 12 scale driver)
sedanaddict is offline
Old 03-04-2004 | 06:27 AM
  #7017
Default diff
I'm not sure, I kinda doubt it as I think the hardness of the ceramic is harder then the rings. When I 1st purchased ceramics for my Tc3, I was trying to find diffrings that mached the hardness of the balls. I ended up buying Niftech diff rings and using Acer ceramic balls. I'll be rebuilding my 12th diff this weekend using ceramic balls. I'm waiting for new rings to come in. Where the diff rings you used new?
acyrier is offline
Old 03-04-2004 | 06:36 AM
  #7018
Yes and no. I had put a new big ring diff from CRC together but hadn't run it yet. I pulled that apart and re-built it with the ceramic balls.
  #7019
rayhuang's Avatar
Blake-if you havent changed the bearing thats next to the adjusting nut-then thats most likey your problem as sedanaddict has said. I'd start there.
Ray
rayhuang is offline
Old 03-04-2004 | 06:39 AM
  #7020
Tried 2 different sets of bearings. I'll run up to the shop tonight and try some new ones.
