8T 2.0
#7516
mines been that way for a while,
#7517
#7520
and then e-mail Angelo at: [email protected]
You can specifically ask him what you need and he will set you up. The products are coming from Australia and take about 10 business days to arrive.
#7521
i'll email for sure.. what voltage are these LiFe packs? i know my charger can do it.. its one of the programs on the LCD, but i know it has to be a different voltage than lipo.
::edit also, can LiFe packs be ran dead? or do you need a voltage cut off, like with lipo and swell your packs?
#7522
Dave I use these horns from racers edge. They are way overkill but never bend or have issues like other horns.
http://www.amainhobbies.com/product_...-Hard-Anodized
#7523
#7524
#7525
Ok I have done a bit of asking around and checked a few things out on my truck to find the cause of the rear main bearing failures that I have had.
One of the engine guys that I deal with had seen this before and suggested that I check the engine mount is flat, as this causes the crank case to warp and stresses the bearing causing it to fail.
I have just finished checking the mount that I had in there and found that there was a small amount of wobble in the motor when it is on the mount and that the top blocks were touching the side of the crank case. This happened on both the motors that I tryed.
So I put the standard mounts on (for the first time in the truggys life) and the wobble went away. At the moment the root cause appears to be my engine mount. This will take time to verify as the failures were a few months apart and we are now moving into winter here.
I am still working out what to do with the quick change mount that I just took off, and I also have a king headz extended mount now to.
For anybody that is interested this article gives an overview of engine mounting:
http://www.massivemods.com.au/produc...roducts_id=352
Thanks for the help I will try and keep this updated
#7526
#7527
#7528
Dave I run the stock stuff and tighten the screws up. I'm scared to use ca glue it might stick in the wrong place. When it gets too sloppy I replace the linkage. I have the double sided racers edge horn but I just haven't modded it to fit. Too busy doing maintence I guess.
#7529
Naw I like my picture better. It's a much better view.
#7530
