Ofna Picco/Jlr .12 EVO 3 RED DOT
#33
#35
#36
I bought a new motoer from a fellow member. I am running 20% fuel. The motor came with 4 shims in three different guages. Should I remove the thinnist one if running 20%? I recall reading that these engines are set up for 30% from the factory.
Any help would be appreciated.
Thanks.
Thanks.
Shawn.
#38
[IMG][/IMG]
I take it the .10mm is the really thin one?
The other three seem to be the same........
Here is what I have.. Which one is this....
I bought a new motor from a fellow member. I am running 20% fuel. The motor came with 4 shims in three different guages. Should I remove the thinnist one if running 20%? I recall reading that these engines are set up for 30% from the factory.
Thanks.
Thanks.
