Old 04-25-2010, 04:10 PM   #31
Ballistik Mods's Avatar
Default picco parts
Guys can anyone tell me where to get parts for the jlr evo 3 red dot in the states.
Ballistik Mods is offline   Reply With Quote
Old 04-25-2010, 08:21 PM   #32
You can give Nitrohouse or Kamikaze a check, you would be able to get all that you need.
jelayne is offline   Reply With Quote
Old 04-25-2010, 09:52 PM   #33
Trader Rating: 9 (85%+)
you cant find a picco parts nowhere but you can get the Mega zx12 parts work. http://ashfordhobby.com
dicksmth_2007 is offline   Reply With Quote
Old 04-26-2010, 06:09 AM   #34
http://www.nitrohouse.com/catalog/in...ath=34_129_211
dicksmith aren't these parts ??
Old 04-26-2010, 06:16 PM   #35
Originally Posted by jelayne View Post
yes but if you need a rod you can find it but you can do this but the CRANKSHAFT and the HEAD BUTTON is not the same http://www.rcdeal.com/modules/stores...m.php?item=156
Old 04-26-2010, 06:59 PM   #36
Originally Posted by DK9mm View Post
I bought a new motoer from a fellow member. I am running 20% fuel. The motor came with 4 shims in three different guages. Should I remove the thinnist one if running 20%? I recall reading that these engines are set up for 30% from the factory.
Any help would be appreciated.
Thanks.
Yes. Take .10mm out the head clearance. It if its not the Tuned version then .40mm should be right for 20%.
Shawn.
Shawn68z is offline   Reply With Quote
Old 04-26-2010, 07:04 PM   #37
Default thanks
Thanks heaps guys for the picco parts info
Old 04-26-2010, 08:47 PM   #38
[IMG][/IMG]
I bought a new motor from a fellow member. I am running 20% fuel. The motor came with 4 shims in three different guages. Should I remove the thinnist one if running 20%? I recall reading that these engines are set up for 30% from the factory.
Thanks.
I take it the .10mm is the really thin one?
The other three seem to be the same........
Here is what I have.. Which one is this....
DK9mm is offline   Reply With Quote
Old 04-26-2010, 08:49 PM   #39
Shawn.
what about for 16%
Old 05-01-2010, 05:56 PM   #40
[IMG][/IMG]
Can someone tell me which version of the JL this is?
Old 05-01-2010, 05:59 PM   #41
Originally Posted by dicksmth_2007 View Post
what about for 16%
Same. 16% to 20% doesnt make much of a difference.
Shawn.
Old 05-01-2010, 07:42 PM   #42
how does this engine compare to the Picco P1-R evo3 engines?
LiL_JaSoN is offline   Reply With Quote
Old 05-09-2010, 11:18 AM   #43
[IMG][/IMG]
Can anyone tell me which version I have?
Old 05-09-2010, 11:27 AM   #44
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it may be the first version of the red dot
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-09-2010, 12:00 PM   #45
el salvador's Avatar
The top view of the heat sink looks like the 1st version (EVO 2), without seeing the end view of the Crank (Shape of the Scallop), can not be completly sure though.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
NitroKB.com: .12 Engine Knowledge Base rmdhawaii Onroad Nitro Engine Zone 42 12-16-2009 03:52 PM
Exhaust pipe question SERPENT7twenty Nitro On-Road 6 08-04-2009 09:18 AM
Picco EVO 3 series DogboneS Onroad Nitro Engine Zone 15 09-26-2008 09:20 AM
