novak
Old 04-27-2010 | 07:03 PM
Default novak
I am trying to get a GTB 4 cell version to work in the brushless mode .I have a lipo 1s 5000 pack and a novak 10.5 motor connected to it.It works fine with a brushed motor setup hooked to it.
With a brushless setup up it just barley moves the motor at wot. And the esc and the motor start heating up. I am following the guide on how to change back in forth from, brushed mode' to brushless mode'..
Am I missin something or has something fried the brushless side of things?
regards
tc3jp is offline
Old 04-27-2010 | 07:12 PM
First reset TX with the one touch setup. If that GTB has the voltage cutoff turn it off. Setting the profile is a little tricky. You have about a half second to hit the button to change it. Unlike other funtions with no time limit. I think thr one touch should defalt to profile 1
speedster1919 is offline
Old 04-27-2010 | 07:26 PM
Ok thanks> I am going out to the shop and try right now
tc3jp is offline
Old 04-28-2010 | 07:09 AM
I just can't get it to work.
One proplem is it is spread spectrum, and the radio I am using is on 75.
I just want to see it work so I can sell it.
Should it work with the radio I am using?
When switched on the motor just runs slow and makes a chattering noise.
And it starts to get hot as well as the speedo itself.
In the brushed mode everything seems to be fine using a brushed motor..
tc3jp is offline
Old 04-28-2010 | 10:17 AM
anybody? anything would be helpfull
tc3jp is offline
Old 04-29-2010 | 03:00 AM
Ah you just found your problem. I've been and done that. The spread spectrum GTB will not work right on any 27mhz or 75mhz radio. I went thur tring different radios and no luck. I sucked it up and bought a 2.4mhz and wow. It works great. Borrow a friends 2.4 to test. Somwwhere on Novak site it does say not to use with non 2.4 TX's
