The Speed Passion Thread >
Like Tree57Likes
Old 02-10-2010 | 11:54 PM
  #2386
Godbreaker's Avatar
hy guys... hav anyone tried using the endless esc with a v3 11.5r motor..?
Godbreaker is offline
Old 02-11-2010 | 07:36 AM
  #2387
irgo's Avatar
Originally Posted by charlie_b
A lot of people found they are also very happy with the stock software.(205G)
Since When 205G become Stock software ?
irgo is offline
Old 02-11-2010 | 07:42 AM
  #2388
abailey21's Avatar
he said that the software that comes on the ESC when you buy it is the 205
abailey21 is offline
Old 02-11-2010 | 07:46 AM
  #2389
charlie_b's Avatar
Super Moderator
"Stock Software" meaning the software the Speedpassions came with.
charlie_b is offline
Old 02-11-2010 | 07:48 AM
  #2390
Cain's Avatar
+1
Cain is offline
Old 02-11-2010 | 08:12 AM
  #2391
The Fox's Avatar
I have to ask because this is getting kind of old.
I have a speedpassion GT2.0 LPF that is having massive problems with calibrating throttle. I have a M8 and synthisized airtornics module and recievers. When I hold the set button down and turn the power on like you are supposed to do, it beeps 12 times then goes into calibration mode like it should. But it will just go into an endless loop of 1, 2, 3 beeps as I do the button presses and trigger movements.
If I let up on the button before it finishes the 12 beeps, it will be silent until I press the button then it will jump to 2 beeps for full throttle. Once I press it at full throttle it does the 3 beeps, I set full brake and the car just takes off at full throttle.
I have it set the best i could now, but that is I need full forward throttle trim and subtrim on it to not go into brake.
I have played with change everything; firmware, neutral range, trim, and sub trim. Any ideas on this problem?
Nick
The Fox is offline
Old 02-11-2010 | 08:17 AM
  #2392
Originally Posted by PinkFloyd
No i've e-mailed schumacher uk and hopefully they can get some of the LCD programmers in stock soon.
Will the new software make a huge difference or not much?
Cheers
There are multiple software within the 1.32 program will give your GT2 a TONS of performance gain compare to the stock 205G that came with the speedo that design for mod motor. And it improve the BRAKE by a lot too.
You just get a hold of the SPEED PASSION LCD programmer card and play with the software....there is NO WAY the GT2 is any slower then SPX. We are all racing the GT2 now against the SXX and Tekin RS. SPX is so 2008.
Solara is offline
Old 02-11-2010 | 08:18 AM
  #2393
abailey21's Avatar
Nick
http://www.youtube.com/watch?v=LX478XKn9cY
Old 02-11-2010 | 08:22 AM
  #2394
charlie_b's Avatar
Super Moderator
Nick
Nick,
To set the ESC, you must do these 11 steps.
1.Turn radio on and put your EPA on 100%.
2.Hold the Set button on your on/off switch and turn your ESC on.
3.Release your Set button.
4.Press your Set button and leave your throttle in the NEUTRAL position.
5.Press your Set button and hold your throttle in FULL FORWARD position.
6.Press your Set button and release the throttle.
7.Hold your throttle in FULL REVERSE position.
8.Press your Set button.
9.Release your throttle. Wait 5 seconds and turn off your ESC.
10.Set your EPA to max.
11. Turn on your ESC. You should be working.
Old 02-11-2010 | 08:25 AM
  #2395
And for stock motor is called "Software for STOCK motor"....
Solara is offline
Old 02-11-2010 | 08:28 AM
  #2396
charlie_b's Avatar
Super Moderator
Howard..now ur starting to confuse me!!!!
Old 02-11-2010 | 08:36 AM
  #2397
No, it is not rocket science...the STOCK software that came STOCK with the STOCK GT2 speedo is setup in STOCK form called 205G that is capable to run with any motor including STOCK motor which alot of ppl will use it in STOCK form to start their STOCK motor racing in STOCK spec and thats why we called it the STOCK SOFTWARE which is NOT the best to use on STOCK MOTOR....is that STOCK enough?
Solara is offline
Old 02-11-2010 | 08:39 AM
  #2398
charlie_b's Avatar
Super Moderator
LOL...that is PLENTY stock bro!!! haha I was just kidding..i know what you meant.
Old 02-11-2010 | 08:45 AM
  #2399
irgo's Avatar
Default Speed Passion LCD Torque Limit
adam when is LCD gets Updates for
adjusting Torque Limit custom value?
irgo is offline
Old 02-11-2010 | 08:53 AM
  #2400
Please SCHOOL me...what is TORQUE LIMIT CUSTOM VALUE?
Solara is offline
