steering dual rate
Dual rate is the total amount of travel both left and right. On a big sweeping track, you might turn it down to 80% so that you don't over steer the car. On a tight track, you would need more travel so you would set it higher.
EPA is the limit you set for each direction of travel by the servo. On my car, the servo can turn 82% to the left before it hits the steering block stop. If I left it at 100% it'll wear on the gears and parts trying to turn farther than it can. The dual rate of 100% would mean that you are turning the full value of the EPA. And don't worry if the Left is 82% and the right is 77% or something. Few cars are symmetrical.
Old thread dug up!
On my TRF416 I m finding that the car is way too glitchy, a small movement on the wheel will cause the car to jump all over the place.
Should I be using the steering dual rate function to limit this? To my understanding the steering dual rate will also reduce my turning circle?
What I want to achieve is the same amount of steering, but just at a slower speed.
My radio is the Airtronics MX-3FHSS.
Thanks!
Thanks!
So does this mean if I have my DR set to 90% I am not getting full steering? another wards will my buggy not turn as tight with DR set to lower then 100%
I thought it just numbed the sensitivity of the the steering?
Your first paragraph is correct. Reduces total turning and sensitivity by the amount you turn it down. (assuming there is no steering bottoming out or travel limiting at 100% to start with)
