Ofna Force .21 JL
Old 12-04-2009 | 07:03 PM
  #31
aaron joy's Avatar
Jud you have one right now, Killer 9
aaron joy is offline
Old 12-05-2009 | 12:50 AM
  #32
merdith6's Avatar
Default Yes.
The picco based ones were terrible, but the older force engines like the 4 port, 6 port and delta force were great engines. The picco ones were discontinued fairly soon after too. The old force engines were great. I had 3 of them and they all worked great. The new black engine looks sweet. For under 200 bucks, sweet.
merdith6 is offline
Old 12-05-2009 | 01:02 AM
  #33
easyryder's Avatar
Old sckool.
http://www3.towerhobbies.com/cgi-bin...I=OFNG5215&P=X
easyryder is offline
Old 12-05-2009 | 03:23 AM
  #34
JUD's Avatar
JUD
Yeah I know Im loving this engine right now.
JUD is offline
Old 12-05-2009 | 05:57 AM
  #35
hey easy what pipes u gonna try....dynamite's i hope
looks like old school p5 ...great motor's
rkhess is offline
Old 12-05-2009 | 08:09 AM
  #36
easyryder's Avatar
TTR 2035 pipes, also have JP-3 to try.
Old 12-05-2009 | 08:22 AM
  #37
easyryder's Avatar
Not a direct copy of the p5, looks like it has a longer stroke if it has the same spec as the Killer 9
Old 12-05-2009 | 09:03 AM
  #38
Maximo's Avatar
the port layout is different then a P5.......
Maximo is offline
Old 12-05-2009 | 06:03 PM
  #39
easyryder's Avatar
Tight like a pancake
Old 12-05-2009 | 11:22 PM
  #40
-R2-'s Avatar
I start with some history I've had with the two, tghe first was the proto and the second is the production, the first one I had before Sept. and got it ready for the Nitrohouse Labor Day Race at Revelation, yes they are tight engines so they do need some time of conservative running before you really dunck on it and the engine a tune when up to temp engine so don't try to do your tunning on the bench. At start the engines run cold and need some revs to bring up the temps so you can set the idle if too cold it will stall. I ran JP-2,3 and 4 and they resopnded the way the pipes were designed, the 2 was still my best option, the engine sounds like an on-road engine when up to speed, it has smooth bottom end and a good floing top speed, with 1.0 springs and our 10013 shoes they got me what I needed to run good to make the a-main, my fuel run time I was putting was 7 min just to be safe but have 9min on a tank to the end and I also still was on the conservative side of tunning since the Sept heat was tipping under and over the 100 degree mark, that engine managed to egt me 4th place in a 40minute race with no flame outs but my drive train was skipping a gear. It was very impressive for an engine with the dollar price that it's going for.
When the production one came in we have run it hard and I mean I have done a short break-in and then wide open, it still reponds the same waqy when cold and when up to temp but it seemed like I need to take a shim out to be on the better end so nothing major in the tunning process after the shim was taken out, the shim is like .023 and didn't have a .01 around which i think is the better way for fine tunning the production runs just like the proto and we were not to veer away or do any major changes to the engines, hot plugs seem to work the best even in high temps, I ran Picco plugs but any thing will work but I feel like what ever you start with you may want to stick to that since the bottom will form after heat cycle. I had run Picco engines strong and was very reluctant about running the engine but now has my full attion and will be my race engine for 2010.
-R2- is offline
Old 12-06-2009 | 01:22 AM
  #41
merdith6's Avatar
Default Sweet
Tower still has stuff from the 80's, strange shop. you can probably get the original grasshopper there. So this new force, it's a 5 or a 7 port. Is the bottom end enough? yo might try the 9853 ss novarossi pipe with the short round header. It will give you enough punch, and the short header won't limit the top end, heck that setup works for every engine I've run. the dynamite 053 will work and it comes with the short round header anyhoo....Also try the mc-coy mc8 plug, it seems to be a medium hot plug that will last a little longer than a dedicated hot plug. But if it's a 7 port you might be right that hotter plug will keep it lit up better and make it easier to tune, maybe. I love the all black case an hardned crank. Sweet for 175, nice comeback force...
merdith6 is offline
Old 12-06-2009 | 04:22 AM
  #42
easyryder's Avatar
Its a 5 port, turbo head engine, long, real long stroke and should have plenty of bottom. I will have it on Tuesday will take pics of internals and give feed back on the engine during break in and race reports
Old 12-06-2009 | 04:45 AM
  #43
JUD's Avatar
JUD
This engine should be really good! Can't wait for your results!!
JUD is offline
Old 12-06-2009 | 05:13 AM
  #44
Wrong thread, forum's messed up again.
K.Copeland is offline
Old 12-06-2009 | 06:36 AM
  #45
easyryder's Avatar
http://www.hobao-racing.com/download...aper800600.jpg
