8T 2.0
#5071
oh ok i see your point..
#5076
yea it seems to lost its real compession for some reason i can turn the flywheel and pop the piston down is that cause of a leak cause there is a wet spots on the carb and the front bearing leaks a bit when the low end is rich cause it hasnt been running right does that cause it to lose compression
cause i only have about 2 gallons run into it
#5082
TC5man, I can't believe you said Hobby Hut is smooth. If you were to look in a dictionary for "blown out track" it would say "see Hobby Hut".
I watched my friend's buggy do a flip down the straight away after hitting a pothole.
It's all in the driver as something mentioned before.
Reggie, you should have seen Adam beating guys in sportsman Truggy with his Traxxas Revo. He made me proud!!
#5083
