Airtronics M11X
Old 11-03-2009 | 08:28 AM
  #166
dameetz's Avatar
Originally Posted by berserk
wow i tried the differential swap! and it is possible, the input is now normal! woohoo! . no need to do the reverse throttle crap. dude i just post my m11x for sale because im so frustrated about this reverse thing.
dameetz thank you so much!
No problem bro...I m glad it worked...
dameetz is offline
Old 11-03-2009 | 08:45 AM
  #167
Zerodefect's Avatar
Are you running brushless?
Can't you just swap 2 of the power wires to the motor to make it run the other direction like any 3 phase motor? Or just program the ESC for backwards op?
And how could it possibly be the M11's fault?
Zerodefect is offline
Old 11-03-2009 | 09:19 AM
  #168
berserk's Avatar
I already tried swapping the wires but the motor wont turn. I think it wont work on a sensored brushless motor. probably on a sensorless motor
i dont think there is a problem with the transmitter because as stated by dameetz above, the reverse mode work on an EZrun esc. so its probably a compatibility issue with the esc's that im using.
berserk is offline
Old 11-03-2009 | 09:40 AM
  #169
I'm glad you were able to make it work bradir! Next time no more beer when assembling your kits! Haha j/k!
iBok is offline
Old 11-03-2009 | 09:11 PM
  #170
mikesd1980's Avatar
I have a question. On my M11 2.4 GSSS I have 3 models and 3 different settings. When the Transmitter is on buggy it will still will operate the truggy just with the buggy settings. Do the M11x do this????? I know the DX3R will not operator the buggy if the transmitter is on Truggy.
I am really like the M11x and I am curious if they fixed this issue. It dont really matter cause I am still getting it though.
mikesd1980 is offline
Old 11-03-2009 | 10:22 PM
  #171
berserk's Avatar
yeah Next time no more beer when installing the differentials.
I wasnt able to fix the reverse thing on my m11x, but im really glad that someone came up with a solution that solved my problem. thanks to dameetz. hes the man!
berserk is offline
Old 11-07-2009 | 12:54 AM
  #172
sandrixx's Avatar
Default ayuzz!
Bradir Berserk, you were so pumped up that you qualified so fast yesterday!!
I guess M11x PLUS your skill= winner!
Bradir Ibok, I going home soon.............lets race together in Manila, oki?
sandrixx is offline
Old 11-07-2009 | 01:42 AM
  #173
berserk's Avatar
brod Sandrixx, thanks for lending me your motor, esc and battery. without your help i will only be watching the race. I was so surprised that I took the TQ. but your serpent is still unbeatable during the race.
yeah! the m11x is really amazing! no wonder most of the top rc racers are using it. the response is so fast and precise. I really felt it because im using the Futaba 3pm before.
berserk is offline
Old 11-07-2009 | 02:30 AM
  #174
sandrixx's Avatar
Default anytime bradir!
You are most welcome Bradir Berserk. I know your driving skills are superb.
And You are one of my best buddies here in Ksa so it's a pleasure helping you.
sandrixx is offline
Old 11-08-2009 | 05:27 PM
  #175
Just got my M11X. SWEET!
Only only one problem. It was missing the instruction manual.
So two questions.
1) How do I use the custom menus? C1, C2, C3
2) What are the different modulations for?
Thanks!
Any one have a PDF copy?
Fred Perkins is offline
Old 11-09-2009 | 08:42 AM
  #176
Anyone have any recommendations as to what 7.4V LiPO to use for the M11x?
Apex is offline
Old 11-09-2009 | 03:31 PM
  #177
dameetz's Avatar
So two questions.
Thanks!
You set whatever you want on the custom menu page and after everything is set...you can press the left and right menu button simultaneously to use the C1,C2,C3 that you have set.
dameetz is offline
Old 11-10-2009 | 03:28 AM
  #178
berserk's Avatar
Try this
http://rcmarket.com.hk/product_info....i59llgllktn486
berserk is offline
Old 11-11-2009 | 07:38 AM
  #179
kyle3333's Avatar
Questions?? Voltage Regulator?????
My M11x is on its way and after reading this thread it looks like I am going to need a voltage regulator for each of my cars. However; someone mentioned that some ESCs regulate the voltage going to the rx. I have an LRP SXX and an LRP SXX TC spec, should I be good to go. I use TrakPower 4900 25c 7.4v LiPos and TrakPower 4800 20c 7.4v LiPos.
I really appreciate your input on this one.
Thank you,
Kyle
kyle3333 is offline
Old 11-11-2009 | 08:21 AM
  #180
berserk's Avatar
Thank you,
Kyle
I dont think you need a voltage regulator. with an LRP i think your good to go! plug and play!
berserk is offline
