Airtronics M11X
Old 10-15-2009 | 11:49 AM
  #136
Does anybody know if Spectrum recivers can be used with the M11x?
florianlaux is offline
Old 10-15-2009 | 11:59 AM
  #137
they can not be used each system(futaba, spektrum, Airtronics ) only work with their own stuff
jinxed is offline
Old 10-16-2009 | 07:50 PM
  #138
Suspended
So you must run a voltage regulator with this system??
Losiracer12 is offline
Old 10-17-2009 | 12:35 AM
  #139
stacky150's Avatar
Does anyone know if you can use a LiPo Receiver Battery as the Transmitter Battery?
Cheers,
Chris
stacky150 is offline
Old 10-17-2009 | 02:35 AM
  #140
Cheers,
Chris
If it can fit, then yes. But this one was made specifically for the M11X:
http://cgi.ebay.com/Intellect-7-4v-2...item2ea7b37838
iBok is offline
Old 10-17-2009 | 08:26 PM
  #141
David Wall's Avatar
Got a freind that just got an M11, he is trying to change from model 1 to model 2, but when he tries, it says display mode only. I tried to make my M11 do it, but no luck. Any idea on what he is doing wrong or what would cause this? As is he can only run 1 car with his radio.
David Wall is offline
Old 10-17-2009 | 10:18 PM
  #142
Ryan Maker's Avatar
Hey,
What he needs to do, is start the transmitter in Display Mode, this is done by holding the "Display" slider on the front of the radio over the the right for about 3 Seconds, and it will turn the radio on, and from there, choose Model Select function and you can change between models. To turn the radio off, push the slider over for about 1 second and let it go, and the transmitter will be off.
Then you can resume by just using the normal On/Off Switch on the Radio, but whenever you need to change model, you always need to do that
Hope this helps,
Ryan.
Ryan Maker is offline
Old 10-19-2009 | 06:57 AM
  #143
I'm thinking about getting an M11x for my bday soon. Anyone have any compatibility\frequency issues with servos or speed controls (e.g. LRP SPX)?
Apex is offline
Old 10-27-2009 | 09:37 AM
  #144
dameetz's Avatar
Default SHR question
Hi guys, I just bought the M11X 2 days ago. I haven't actually use it yet, at the moment I m just running through the instruction manual. I have questions regarding setting up SHR mode.
As I understand I can select SHR mode on any individual channel, does this means if I use digital servo for steering and analog for throttle, so I can select SHR only for steering and NOR for throttle?
Which mode for throttle should I use if I m running ESC? with digital servo for steering.
This is my first Sanwa/Airtronics radio so I don't know much about their system. My background is Futaba and KO radios where if you select HRS or HSR you have to use all digital servos with it coz the whole system(channels) will be in that mode.
dameetz is offline
Old 10-27-2009 | 01:51 PM
  #145
technazi's Avatar
You can use digital or analog servos in the normal mode of the M11X. However, if you want to speed up your digital servo's performance, switch that channel the servo is on to the SHR setting. As for your speed control, simply keep that channel in the NOR mode as changing it to SHR mode will probably cause the speed control to not function properly as it doesn't operate at that fast of a frame rate.
technazi is offline
Old 10-29-2009 | 05:18 PM
  #146
As long as the esc you're using regulates the 4.8v to 6.0v range you should be fine. I run LRP and most of their new esc's will manage the voltage to the receivers and servos.
Can't wait, picking up my M11x tomorrow!!
Apex is offline
Old 10-30-2009 | 02:12 AM
  #147
berserk's Avatar
Good day everyone,
Im having problems with my m11x. my car is running backwards when I hit the throttle. I tried to reverse the throttle function, but during reverse mode the motor is running even at neutral. please help?
Regards.
berserk is offline
Old 10-30-2009 | 09:04 AM
  #148
dameetz's Avatar
Originally Posted by berserk
Good day everyone,
Regards.
Try calibrate your esc with the radio.
dameetz is offline
Old 10-31-2009 | 05:42 AM
  #149
berserk's Avatar
tried this already but the motor keeps on running even without pressing the trigger.
anyone using the m11x could you please try the throttle reverse function on your radio and see if you will encounter the same problem. pls help my head is going to explode on thinking how to solve my problem. .
my kit is a TB03, the motor rotation is opposite of the belt drive car.
Thanks and Regards to everyone.
berserk is offline
Old 10-31-2009 | 07:14 AM
  #150
recalibrate the ESC itself, using the setup button in the ESC... that should fix it.
iBok is offline
