Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 10-09-2009 | 12:19 PM
  #10426
Jam-ehz's Avatar
Originally Posted by scribbler
Has anybody seen the new ball diff for the M05? I'm interested in knowing if the cups that secure into the diff are slots like the new gear diff, or if they have the same spindles?
I think your answer is neither of those..
It'll be a one-piece diff when assembled, no drive cups that notch into the ends like the older diffs did.
Jam-ehz is offline
Old 10-09-2009 | 03:25 PM
  #10427
gtfour93's Avatar
Originally Posted by Hyde
wow that's ugly! They should have came out with the original!
With the window tint removed and better offset wheels (adding spacers), it will look nicer.
gtfour93 is offline
Old 10-09-2009 | 06:18 PM
  #10428
gashuffer's Avatar
What's a good starting point with the M chassis oil dampners? Oil, piston and springs f/r ? Thanks
gashuffer is offline
Old 10-09-2009 | 06:33 PM
  #10429
tamiyarcracer's Avatar
Built per box instructions work very well, as a starting point.
I think I have 60w in mine for the carpet, and stiffer springs, from the box settings
tamiyarcracer is offline
Old 10-09-2009 | 06:40 PM
  #10430
gashuffer's Avatar
The kit comes with blue, yellow and red. What are the rates?
Old 10-09-2009 | 08:40 PM
  #10431
White spring with the blue dot, front
White spring with the yellow dot, rear
Old 10-10-2009 | 07:28 AM
  #10432
Does anyone have the part number for the heat sinks that mount to the new M-05 aluminum motor plate?
Crashby is offline
Old 10-10-2009 | 07:31 AM
  #10433
RossoTorro's Avatar
Tamiya #53924 DF-03 Heat Sink Bar Set
RossoTorro is offline
Old 10-10-2009 | 01:14 PM
  #10434
cannon's Avatar
Or Rc Model in HOng Kong has some really nice brass ones as well
cannon is offline
Old 10-10-2009 | 04:36 PM
  #10435
tony gray's Avatar
It's the Xevo M03/05 conversion. What's it like? You better believe you'll want one...
Check out the story HERE about this innovative new M chassis racer.
And find out how Tim made a SWB/MWB kit into a LWB one as well!
tony gray is offline
Old 10-10-2009 | 05:10 PM
  #10436
gashuffer's Avatar
One more question guys sorry. With the M-chassis oil dampers it says to put a o-ring under the piston. Are you guys leaving it out? My chassis sits at arms level but now the body is to high and the battery wires are hanging out of the side below the body.
Old 10-10-2009 | 05:41 PM
  #10437
caltek1's Avatar
Great article Tim and TFG on the Xevo. Sounds like it is a great conversion and even better to drive.
Hope to have one going soon.
Regards,
Calvin.
caltek1 is offline
Old 10-10-2009 | 05:46 PM
  #10438
caltek1's Avatar
gashuffer,
On the MO3 I build the TRF M Chassis shocks as per instruction, including the "o" ring. For a MO5 I omit the "o" ring. You have options with regards the pistons:
3 hole 50 wt oil front 40 wt oil rear
3 hole 60 wt oil front 50 wt oil rear
2 hole 40 wt oil front and rear
2 hole 30 wt oil front and rear
Comes back to how you want the car to react.
Happy racing.
Regards,
Calvin.
caltek1 is offline
Old 10-11-2009 | 07:21 AM
  #10439
cartix's Avatar
Thanks for this article Tony. That's one sick conversion!
cartix is offline
Old 10-11-2009 | 07:44 AM
  #10440
los limbos's Avatar
Originally Posted by caltek1
gashuffer,
Happy racing.
Regards,
Calvin.
Hello,
You are talking about 30wt and 40 wt oil.
I ám use Tamiya oil, is 30wt the same as 300 from Tamiya and 40wt as 400??
Or exist there a conversion table for.
Best regards Bart
los limbos is offline
