Like Tree248Likes
Tamiya mini cooper
Old 10-11-2009, 08:48 AM
  #10441
Question regarding the fan on Ezrun brushless systems:
On my M-05, I'm finding that the fan on my ESC is getting clogged up with carpet fibres from our track very quickly, one race and it's time for a clean to keep it spinning smoothly. Maybe it's due to the ESC being closer to the ground, as I don't get anywhere near as much trouble with the same ESC in my M03, but it is mounted on top of the chassis.
Has anyone tried removing the fan completely, and has it caused any heat problems with the ESC?
The main reason I ask is because I've just read the Xevo review on RCMini, and noticed from the pictures that the Ezrun ESC in that Xevo didn't have a fan on it. I guess if it doesn't cause any problems in Australia, it should be fine in colder climates?
Toon is offline
Old 10-11-2009, 09:53 AM
  #10442
NT
NT's Avatar
Trader Rating: 21 (100%+)
Hi Toon,
They work fine without them. Im not sure they do heaps of cooling anyhow. Not sure if this is the one that Tim removed on purpose to fit in the rear of his M03 chassis, or if its one the fan stopped working on, so it was removed.
Undo the 2 screws holding it on, snip the wires and you're done. Or, you can re-position the fan and mount it with double sided tape somewhere else to blow air onto the esc. Im not sure it would do a whole lot though!
NT is offline
Old 10-11-2009, 10:23 AM
  #10443
could anyone tell me whether the M Chassis TRF Shocks (part number 54000) actually drops the ride height, or whether it stays the same on an m-05.
s22jgs is offline
Old 10-11-2009, 10:50 AM
  #10444
Hyde's Avatar
Originally Posted by tony gray View Post
It's the Xevo M03/05 conversion. What's it like? You better believe you'll want one...
Check out the story HERE about this innovative new M chassis racer.
And find out how Tim made a SWB/MWB kit into a LWB one as well!
wow looks sick! Two things ill be worried about.. Those open gears...those teeth or no wide and just....tamiya plastic! I could see a nice rock getting cought and chunk a tooth out..
Another..that low profile servo looks really trick on that chassis I've loved them on the m03 back in the day! But not everyone has them..would be be able to use a regular servo to run it?
Those FF yoks were sick! I wrote an article back in the day about them and yes they were banned! FF01's didn't have a chance!
Hyde is offline
Old 10-11-2009, 03:44 PM
  #10445
gashuffer's Avatar
Trader Rating: 48 (100%+)
It drops the ride height to arms level.
gashuffer is offline
Old 10-11-2009, 04:02 PM
  #10446
b3buggy's Avatar
Hi Steve,
been running mine without a fan in the M05 since I have had mine, no problem. Even run it without a 'proper' heatsink in the 1/12!
Ross
b3buggy is offline
Old 10-11-2009, 05:41 PM
  #10447
RossoTorro's Avatar
We run them withouth fan in F103's also.
Not a problem even with the small space inside the F1 bodies.
RossoTorro is offline
Old 10-11-2009, 07:05 PM
  #10448
cannon's Avatar
Trader Rating: 35 (100%+)
YOu can run the regular servos They are just mounted standing up so that you still have room for the battery
cannon is offline
Old 10-12-2009, 02:31 AM
  #10449
edwintklee's Avatar
Trader Rating: 23 (96%+)
would be easier to understand if got photo of how to do it,
edwintklee is offline
Old 10-12-2009, 02:38 AM
  #10450
cannon's Avatar
Yes, the instructions with the Xevo are a bit vague but it doesn't take too much to work them out.
cannon is offline
Old 10-12-2009, 03:58 AM
  #10451
Tim K's Avatar
Toon, NT is correct, I took the fan off so I could fit the ESC in the rear of the M03 chassis.
Haven't noticed any difference in the performance, the motor/esc barely get hot.
In the UK you shouldn't have a problem.
Hyde, the open gears on the Xevo are a concern, but so far there hasn't been any rocks caught in there.
If you check the photos on rc-mini you can see that there is a 10mm+ gap between the rear of the lipo and the rear alloy bulkheads.
So if you put a standard servo in the lipo will move back by 10mm and fit just nice.
Tim K is offline
Old 10-12-2009, 05:44 AM
  #10452
Steve - As Ross says it should be ok. I don't think my fan has worked in weeks, at least the ESC is down in the airflow on the M05. I'd love to know why your Chewbacca spec chassis picks up so many carpet fibers in the first place.
V1nce is offline
Old 10-12-2009, 11:05 AM
  #10453
los limbos's Avatar
Hello,
You are talking about 30wt and 40 wt oil.
I ám use Tamiya oil, is 30wt the same as 300 from Tamiya and 40wt as 400??
Or exist there a conversion table for.
Best regards Bart
Can someone help me!
los limbos is offline
Old 10-12-2009, 11:16 AM
  #10454
Pro10noob's Avatar
Never mind you allready changed it to english
Pro10noob is offline
Old 10-12-2009, 11:30 AM
  #10455
gashuffer's Avatar
Originally Posted by los limbos View Post
Hello,
Best regards Bart
Yes 30 is 300 40 is 400 and so fourth. The only shock oil that I know of that is slightly different than the others is Losi.
