Like Tree195Likes
Novarossi engines thread
Old 07-27-2009 | 12:58 PM
  #3301
Originally Posted by Nitro-Racer*
..so we are paying extra money for the coating....
Ehm.... yes......
I have read somewhere the coating is a reinforcement of the crankcase but I doubt it will make the case stronger. But you will never know what the teamdrivers are using, maybe their cases are from a different matirial.
Once I swapped the internals from a JP Eagle over to a crankcase of a 35+ due some problems and I did not notice a difference in performance.
Roelof is offline
Old 08-02-2009 | 04:53 AM
  #3302
prg
Hi Guys
Can anyone explain why the 353 comes with 2 low end needles. ships with a short one and a longer one in the packet of bits. Under what conditions would each be used.
Thanks heaps
Peter
prg is offline
Old 08-02-2009 | 05:07 AM
  #3303
Winner's Circle's Avatar
Originally Posted by prg
Hi Guys
Thanks heaps
Peter
I have never run a 353 because I am a 1/8 guy but years ago Picco had an engine with 2 needles and 2 seats. The short needle was fatter and delivered big power but it was very abrupt. The long needle had a smaller diameter was smoother and easier to drive.
On high traction tracks the short fat needle was the hot ticket and on low traction the longer thin needle was best.
Hopes this helps.
Lee
Winner's Circle is offline
Old 08-02-2009 | 05:52 AM
  #3304
The coating that is on most of the black or gray crankcases is a hard coating and it changes the actual Rockwell rating for the hardness of the material used in the crank case. Rockwell is a measurement used to rate the hardness of materials. So the case will usually display signs of more rigidness and less flex.
xspower is offline
Old 08-02-2009 | 07:33 PM
  #3305
chromie's Avatar
Hey.. what would be the best pipe to run with a Novarossi 359 RACE .21
chromie is offline
Old 08-02-2009 | 10:08 PM
  #3306
Boz
Default conical or non conical
What are the differences in performance of these manifolds for 1/8th on-road
41016 (med conical) and 41023 (med non conical)
Boz is offline
Old 08-03-2009 | 04:37 AM
  #3307
Pattojnr's Avatar
conical = more power more fuel
non conical = better fuel economy and less power.
but with what you are getting in power wise, could be a good trade off to try the non conical or if thats what you are using now, then try my Conical next meet drifter garanteed hahaha
Pattojnr is offline
Old 08-03-2009 | 05:10 AM
  #3308
Boz
MMMMMMM... power
Boz is offline
Old 08-08-2009 | 12:31 AM
  #3309
asw7576's Avatar
Originally Posted by jelayne
Does anyone know the reason for the new case on the 353 '09, from the pictures posted all the top Novarossi guys were running with a grey case instead of the black that sells.
Or is it another 353 '09 to come with the original Purple head ?
Balestri
Pietsch
Dirk
Why those cars have two extra body post behind rear shock tower ?
asw7576 is offline
Old 08-08-2009 | 02:06 AM
  #3310
It stiffeners up the body.
Roelof is offline
Old 08-08-2009 | 06:08 AM
  #3311
Bad Mika's Avatar
Default novarossi 353 '08 & '09 edition...
hi,
what is the performance difference between the novarossi 353 '08 (blue head) edition vs the new '09 (purple head) ?
also notice the new 2652 pipe ?? many thanks :-)
Bad Mika is offline
Old 10-04-2009 | 06:07 PM
  #3312
Default 353 '08 / '09 conrods
Can anybody tell me the difference between the 353 2008 & 353 2009 conrods?
They have different part numbers (NOV07602 for '08 and NOV07604 for '09).
Are they interchangeable?
Thank you
Fernando_M is offline
Old 10-09-2009 | 09:33 AM
  #3313
Hi Guys, just willing to let you know that the Novarossi On Road engines are in. All of them in stock. Pipes, headers, plugs, etc, etc are in stock.
Check our dealers or go to serpentamerica.com
Paolo M is offline
Old 10-13-2009 | 09:09 AM
  #3314
Dreddlox's Avatar
just want to verify that the Plus 12- 3SCT and the 353 '09 use the same con rod? I need to replace them and wanted to be sure before I order it!
Dreddlox is offline
Old 10-13-2009 | 09:23 AM
  #3315
They do not use the same con rod. The rods have different part numbers anyway. 07601 for the SCT and 07604 for the 353 '09
Scott Fisher is offline
