8T 2.0
#4636
#4637
#4638
Check your rear brakes, they maybe grabbing way to much, normally, you set about 60 rear and 40 front, you do not want the brakes to lock up when braking, just grabbing tight enough to slow you down quickly, if when your breaking, and they locking, that will throw the ass all over.
#4639
Thanks guys, I think I need to go back to the standard setup and up the diff oils and see how it goes.
I actually turned the rear brakes right down cos I thought they might be grabbing. So don't think that could be the issue.
#4640
Guys this weekend I will be running on an indoor blue groove track (which I normally do not). I currently run the drake standard setup with lighter shock oil, what are some things I may look to do to help the truck. I am just thinking in advance as I have never run on a track like this. The truck may be spot on, but if its not I am asking for suggestions. Can't wait for this race looks like it is going to be off the chaon!!!!
Thanks guys
Jason
Thanks guys
Jason
#4641
Thanks guys
Jason
Thanks guys
Jason
#4642
#4644
#4647
has anyone raced at thunder alley is cali with the 8t 2.0? if so can i get your set up either pm me or email [email protected]
I am going nov 7-8 for sidewinder race. I am going to try my current set up there but would like to see if people are changing there set up for this track.
#4648
#4649
I went back to stock on sunday (dry astro,grinders,OS 28) stock diffs were fine but only got 20 mins out of the centre then it was cooked, for the final i went white springs on the front and purple on the rear .. it made it very twitchy , in hind sight i think i will have to move the shocks out on the lower arms or not run grinders, the car had no push but loads of grip .. some of the corners were James Bond style lol
#4650
