The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 09-09-2009 | 09:14 AM
  #271
Originally Posted by 1fastguy1
what kind of runtime did you get with the 2013?? I just got one to try and plan to try it this weekend
I only ran it in the main so I had no reference. I came in at 7:30 and Al said it wasn't close to empty. I was on and off the stand with other issues after that. I'm guessing about 8-9 min. easy for the layout this weekend.
sstoffer is offline
Old 09-09-2009 | 10:18 AM
  #272
BermyDomRepRC's Avatar
WASSUP rON GOOD TO SEE THE NEW ENGINE IS GETTING GOOD REVIEWS MAN KEEP IT UP
BermyDomRepRC is offline
Old 09-09-2009 | 05:05 PM
  #273
Hey guys, just made it back from vacation and trying to catch up on everything (so if you sent me a pm over the last couple of days i will be getting back to you shortly!). Just wanted to see how everyone was doing with their engines so far?
Mo, let me know what you think once you get a chance to try the 2013, I think that you will really like it! I just got the 2056 and 2057 samples in today and sent them up to Kortz who should be running them over the next week so I'll have some comparative info that I'll bounce off of you to see if it jibes with your results. Also sent you an e-mail today regarding the missing shipment, let me know if you got that.
sstoffer, sorry to hear about the bad luck with the Trinity Big Boy pipe! What did you feel was the performance difference when you switched to the 2013?
Marcus, you're right the 2013's are nto the easiest thing to find right now! However Italy is now back from vacation so I should have some more available in about 2 weeks at the shops!
smb17, glad to hear that everything is good on the engine!
BermyDomRepRC, I'm assuming that's you Keenan lol! Thanks bud, the response so far has been really positive and I'm stoked! We put a lot of time into developing this engine and it's looking like it will pay off! You still in Bermuda or did you make it back home yet?
Regards,
Ron Hopkins
Werks Racing
Werks is offline
Old 09-09-2009 | 06:28 PM
  #274
smb17's Avatar
Welcome back ron! Let me know what kortz thinks! Did he run the bigboy pipe yet? I'm not convinced that the engine liked the pipe. but it did have some nice run times.
smb17 is offline
Old 09-09-2009 | 07:25 PM
  #275
I just got them on today and sent them to Kortz so he will not have them until Friday but I should have some initial testing results early next week. Regarding the 2056 (big boy pipe) I have the feeling that it also mght excessively mute the bottom in the engine (but some people might realy like that). However I already talked to Kortz about thY and we are going to see if we can clutch the engine lighter to make up for any loss in punch while still retaining most of the improvement in fuel economy! In a nutshell we have quie a few things that we are going to play with including a new 3 shoe traditional scissor style clutch design that we can adjust spring tension on that I might be releasing if testing works out ok. So.... stay tuned, whatever we come up with I will pass on to you guys!
Before I forget, congrats go out to Kortz for winning last weekends Nitro House race at Revelations running another box stock B5 engine & Werks "Race Blend" fuel in his Hyper 9! Another podium finish for the little $200 engine that can
Werks is offline
Old 09-09-2009 | 08:13 PM
  #276
smb17's Avatar
I believe chad runs werks fuel so that means a one two finish
smb17 is offline
Old 09-09-2009 | 08:56 PM
  #277
That is correct. We also took second and third with our fuel at last weekends Nordic Championship in Europe that you guys might have read about on Neo Buggy! Great results but unfortunately we did not win it like we did last year but I guess you can't win everything lol!
Werks is offline
Old 09-09-2009 | 10:19 PM
  #278
smb17's Avatar
Will there be seperate parts soon? I'd like to buy another cooling head some time. Already bent it =P I'd like a back up just in case it I do more damage!
smb17 is offline
Old 09-10-2009 | 06:12 AM
  #279
I thought going back to the 2013 was just overall more power. Biggest difference was on the bottom. I had clutched the car for the 2056 so it was a bit too much with the 2013 especially with the good night air we had last weekend. I will be at the RAC and I think Mo will also so it will be interesting to compare his setup to what I’m running.
sstoffer is offline
Old 09-10-2009 | 11:13 AM
  #280
Mo & I will be in Huntington for the W.V. State Champs race... Hopefully with some better results this weekend then last, for both of us...lol
I just gotta get a pipe...
-DC-
smitty2802 is offline
Old 09-10-2009 | 02:46 PM
  #281
Hey guys quick question regarding tuning. After mid to high speed running I come in and the idle drops low and then comes back up. Would this indicate a lean low speed setting. And when I say it drops down low I mean it's at the point of barely running for a few seconds and then it will come up to a somewhat high idle. I'm thinking lean on the low and rich on the top. What do you guys think? Thanks
AsSc8 is offline
Old 09-10-2009 | 03:15 PM
  #282
It may sound obvious but make sure to check that your throttle linkage is setup properly. If the return spring isn't tight enough to return it when you bring it in and hit the brake it comes to the "right" idle and when you let off it bumps the linkage just enough to give it just a tick of throttle. A quick test is when you stop it and the idle comes up hit the brakes again if you have let off and see if it returns to low idle. If it don't then try to richen the bottom a tick or check for a typical air leak, or exhaust gaskets that may be worn.
Jonathan Bell is offline
Old 09-10-2009 | 03:55 PM
  #283
Garet Jax's Avatar
Originally Posted by Werks
2) ...
Now with the radio gear on, engine off and the slide closed look down the throat of the carb and slowly start to pull the trigger. Take note of the how much throttle you are giving at the point that the low speed needle (which is connected to the slide) comes out of the spray bar (the hollow tube) on the opposite side of the carb. We will use this as a referance for tuning later on but basically what is happening is that during the range of throttle movement that the low speed needle is embedded in the spray bar, the low speed needle will affect fuel delivery (for the purist we both know that this is a simplified explanation as the fuel first travels through the HS needle circuit before going to the LS but since we already set the HS to a rich setting and will not be touching this for a while it's pretty much a mute point). At the point that it is out of the spray bar the fuel delivery (or tune) is affected solely by the high speed needle.
Then I re-install the air filter, fire up the engine and toss it on the ground. Start slowly doing figure eights at say 3 to 4 mph until you run through the tank. Then for the next tank i fire the engine up again and back the idle screw out a couple of hours. You will immediately hear the idle speed start to reduce, to compensate for this I then lean the low speed needle a couple of hours until I again hear a smooth steady idle. Once I have this I then start doing figure eights again but now a little bit fasted until the tank is empty. Next tank fire up the engine, back idle screw out a couple of hours, lean LS needle a couple of hours, do figure eights a couple of mph faster.
Basically what I'm doing with this system is slowly reducing the amount of lubricant being pumped through the engine while at the same time slowly increasing the amount of load that is being put on the engine. This I keep on repeating until I get to approximately the point that I'm pulling the trigger far enough that I know the low speed needle is being pulled out of the spray bar (remember we checked this initially while we had the air filter off) at which point your air gap (the amount the slide is help open by the idle stop screw) will have been reduced to aprox. 1-1.5mm.
Hope this helps!
Regards,
Ron Hopkins
Werks Racing
Ron,
I am on this stage in the breakin/tuning process. The bolded part is the one I am having issues with. I just don't know when I am done leaning the low speed needle and backing out the idle needle. Is there a point where the engine won't run any leaner regardless of how much air I give it or vice versa? Is that the point I am trying to get to?
The low speed needle comes out of the spray bar at full throttle when I have travel set to 55%. I am having trouble determining how this affects when I am done leaning out the low speed needle or backing out the idle screw.
Right now I have travel set to 30% so I don't push the engine too hard.
Thanks a lot.
Garet Jax is offline
Old 09-10-2009 | 06:06 PM
  #284
san.'s Avatar
Hello Team_Orange, all of our engines are set up out of the box to run 30% nitro!
Regards,
Ron Hopkins
Werks Racing
This setup has 2x .3mm and 2x .2mm for a total shimming of 1.0mm?
What would be the ideal thickness setup for 20% and 25% Nitro, respectively?
san. is offline
Old 09-10-2009 | 06:11 PM
  #285
smb, parts will start being available with the next shipment that comes in (so another week or so).
Regards,
Ron Hopkins
Werks Racing
Werks is offline
