BMI's DB12R
#7816
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
#7817
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Hey Jason,
Happy Birthday!
TD
Happy Birthday!
TD
#7818
Hey guys just need a little insight.
I have the org db12r not yet the rr or lipo version.
here the questions. I'm a bit strap for cash these days. so i'm planning on running the car with lipo. with a brushed 27turn.
Will be up grading the car to full lipo and rear pod to RR version in the next couple of month then up grade to bushless hopeully by november.
could any one give me a decent setup for a tight narrow indoor carpet track.
oh yes were allowed to use paragon at out club.
Thanks in advance
Thanks in advance
#7819
Thanks in advance
Thanks in advance
BMI .20 springs
10 deg blocks; mabey fives if the grip is really good
shims middle
5000 on the kingpins
Jaco lilacs
ride height 4mm
Mid:
25wt oil blue/gold spring (original shock)
40wt oil blue/gold spring (silva or other bladder shock)
Med ballstud, shimmed as needed to clear the lipo
Shurlube #4 in the tubes
Rear:
Droop 1 to 1.5 mm
Jaco Yellows or Oranges if availible in your area
Make sure you use a booster or rec pack and this will get you in the ballpark. I've ben running the lipo in my original r car for months and its great.
#7820
#7821
Jason,
I sent you a couple of emails and a pm about the parts needed.
Chad
Chad
#7823
Gadget and I will be going to vegas. Will be running wgt and 1/12th.
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#7824
Yup
I'm officially on vacation now and working on rebuilding my DB12RR and DB10R for the race.
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#7825
#7827
Question for you guys running the lipo car. What flex plates have you found to work best?
#7828
Well got all my bodies mounted and cut up finally...now just to paint them. Got my Novak Smart Booster mounted as well. I ended up using Shoe Goo to hold it in...servo tape just wouldn't give me a bond I could trust on it since the bottom isn't flat.
#7829
Moderator
Last night I raced at our local track, I run a 10.5T/1S DB12RR-LiPo. I came in 2nd in the race because of a badly place brick on the track, but before that I had opened up almost a 2 lap lead. I set the fastest single lap of the day, fastest averages for 5,10,20 laps for the main. The car was insanely good to drive, not the fastest on the straight but lightning on the infield.
Front:
5Deg caster blocks
-1 Camber
Neutral toe (slight toe in on compression)
Flat servo
BMI linear .20 springs (I think... I need to check they may be 22, I will verify and edit this)
very little shock oil on the king pins just to make it move smooth
Jaco Black fronts, trued downa mm or so from stock. (I dont have the measurements on hand)
Front Ride height: 4mm - 4.5mm
Middle:
Silvia center shock, gold spring and 50wt oil.
Mounted in the tall position (sorta, I am using a different front shock mount but its right around there)
LiPo in its lil pocket held in via the rubber band running under the Oring latch points.
Thick (standard) flex plates mounted in the long position.
Damper tubes - I think sure lube 3 (could be 3 or 4, but its teh thinner of the two, been a while since I re-did them)
Ride height: 4 - 4.5mm
Back:
Ride height: 4 - 4.5 mm
Jaco White foams. (I chunked my yellows badly and only had one set of whites with me, they turned out to run very good!) Trued to 1.70" I believe.
Diff was a bit tighter than normal since I havent rebuilt it in a few months now and worked great with the powerful 10.5.
~1mm droop.
Gearing: 78T Spur, 40T pinion
Motor: Orion Vortex V2 10.5T with 0 deg timing.
ESC: Novak GTB 4 cell.
Batt: SMC 4900mAh 40C
Attached is a pic:
