Tamiya F104 Pro!
#452
Is there any way to run the F103 front wheels/tyres to try the different compunds? I killed a new set of kit tyres in less than 30 minutes track time but only 2mm off the rear
#454
it softens the foam, = more wear i think.
looks everyone here has same problem with the front tire.
would try the harder one (type B)
running F104 is a lot of fun, but..
change front tire every race day = not fun anymore..
#455
What arbor works? I tried the d-drive one for f103 my buddy had and it worked for the rears, but the front rim hole was too big for the arbor to hold
Ran my F104 with 17.5 first time. Pushed alittle as the rear was stuck but tightening the nut on the top damper plate thing helped alot.
I ran 4 runs of 6 mins with hardly noticable front tire wear, high grip asphalt 160'x90' track
#456
http://d-drivesportsenglish.com/inde...roducts_id=438
#457
i thought so, same as rubber tires if we use paragon fx.
to a degree yes, but in reality not necessarly.
Foam tire wear in front comes from scrubbing/lateral friction.. that is to say the friction generated by the angle of the wheel and the grip of the tyre.
By using traction compound, you give the tyre more grip, hence more turn-in for a given degree/angle of steering.
If you reduce your steering throw (less epa) while having more inherent grip, you will keep decent handling specs while reducing a little the wear.
it will not be perfect, but it will help.. !
#458
oh i see. yes it does make sense now.
#459
hi Guys,
We have setup a new blog for the F1 which we hope more of u guys to share your comments and photos with us.
here the link : http://rrcf1news.blogspot.com/
#461
I think the wear rate is on both your driving style and toe-in/out you set for your F104.
For me, I like to throw the car when I really need to take the corner tighter to overtake, but any other times, I will drive smoother into the corners to reduce my pocket wear (for the obvious reasons).
I never use those traction compound also for the same reason: pocket wear. The only time I remember using it was at a carpet race.
Besides our topic, you guys should have realised that Tamiya made a bigger wheel set for the F104. And for that, they came out with thinner tires. I see it both ways; big wheels so when the foams wore out, it would not scrub the chassis, thin tires to keep changing tires.
I'll try to help in whatever way I can.
Alfie
Alfie
#463
Alfie
Alfie
#464
