NEW NOVAROSSI 2009 ENGINES
Old 06-25-2009 | 02:53 PM
  #136
JetMD's Avatar
It all depends on which break-in method you use. I have used one method where it still had alot of pinch afterwards and i've used other methods that had almost no pinch afterwards.
JetMD is offline
Old 06-25-2009 | 05:24 PM
  #137
IQ0's Avatar
IQ0
Thanks....would you mind to let me know on which break-in method you're using?
IQ0 is offline
Old 06-25-2009 | 06:08 PM
  #138
jt415gz's Avatar
Originally Posted by Roelof
It positions the spraybar into the airflow, see it as a finetuning if you want (and can get) everything out of it.
Good to know...maybe you know what the factory setting is?
jt415gz is offline
Old 06-25-2009 | 11:11 PM
  #139
The advise is to keep it flush to the housing.
Roelof is offline
Old 06-25-2009 | 11:46 PM
  #140
JetMD's Avatar
Well, that's something that alot of people like to debate. I don't know what's best and i'm not going to claim what I do is the best because someone will want to argue.
All I will say is, this is what I use: http://cefx.net/catalog/breakin.php Just so you know, you will have a decent amount of pinch left doing this method. I also had an engine expert look at my motor after break-in and he said whatever method I used is a good one because the motor looked like it had been broken in right, in his opinion and he didn't know what method I used. This method seems to be pretty popular and I haven't heard anyone say that they didn't like it. Doesn't mean someone out there doesn't though...
If you want hardly any pinch left after break-in, use Mike Swauger's method. He posted it on rctech somewhere and I used it on my plus 12 and that motor has been really good to me. But, I think it's getting worn out a little too fast and it might need a piston/sleeve soon. Hope that helps.
Paul
JetMD is offline
Old 06-26-2009 | 01:05 AM
  #141
jt415gz's Avatar
Thanks Roelof for the input.
NOW who knows if it is fairly safe to NOT use any type of air filter breaking in an engine on the Hudy Break-in Bench? The manual says an air filter is not used on their Break-in Bench. Plus there is no room for it installed on the engine.
http://www.hudy.net/xhudy/products/p...89&kategoria=0
jt415gz is offline
Old 06-26-2009 | 01:09 AM
  #142
I don't use a filter on mine. Just make sure you are in a clean environment when breaking it in.
JASON MAC is offline
Old 06-26-2009 | 01:18 AM
  #143
jt415gz's Avatar
Hey Jason...no air filter I'll try that...how is R.A.M.S these days?
What happened to the MRX4X?
Are you running the Evolva M3 nowadays?
I just built my M3 a few weeks ago...and it is very similar to my old Mugen...just picked up a Flash .21, gonna break that in this weekend (hopefully)
Hope to get back to R.A.M.S. again soon (too much work here in S.F.)
Take it easy~
jt415gz is offline
Old 06-26-2009 | 01:21 AM
  #144
You can use a smal piece of clothing mounted with a tirewrap directly on the carb and oiled a bit.
Roelof is offline
Old 06-26-2009 | 01:24 AM
  #145
jt415gz's Avatar
cool. another good idea. i could also cut out a piece of foam from an air filter oiled up! But that might get sucked in and never be found again
jt415gz is offline
Old 06-26-2009 | 03:01 AM
  #146
You can glue a piece of foam into an insert.....
Roelof is offline
Old 06-26-2009 | 06:54 AM
  #147
IQ0's Avatar
IQ0
sorry...double entries...
IQ0 is offline
Old 06-26-2009 | 06:58 AM
  #148
IQ0's Avatar
IQ0
All I will say is,.......
Thanks mate...at least you'd provide me with the extra info that i'm after here...
IQ0 is offline
Old 06-26-2009 | 07:06 AM
  #149
rjr
For a filter on a break-in bench, just take the foam off the rubber base of one of your filters and tie wrap it onto the carb. No worries about dirt getting in.
rjr is offline
Old 06-27-2009 | 01:14 AM
  #150
Originally Posted by BLKNOTCH
I ended up going with the 353 09 so I am very interested in the pipe question also. I am currently using the 2630 with great results but I am interested what is noted as best for the 09. I will be trying the 2620 also along with the 2601 as these are the 2 I am thinking to get otherwise I will just get another 2630.
Get the 2652. It performs similar to 2630, but certainly doesn't drink gas like 2630. But, it is hard to find tho.
silverM3 is offline
