Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 06-17-2009, 11:39 AM
  #16621
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Thraex
what about the new DCJ driveshafts, when will they arrive?
speedtechrc.com has them in stock. call Jeff (the owner). he'll hook you up.
Hebiki is offline
Old 06-17-2009, 03:19 PM
  #16622
EJ20's Avatar
Originally Posted by Hi-LowBlow
I would like to let everyone know that we have #67699 DCJ Drive Shaft Set (1pcs) in stock now. You can also order it drectly from us if you can not find it at your LHS.
Thanks!
www.hotbodiesonline.com
U.S.A.
EJ20 is offline
Old 06-17-2009, 04:47 PM
  #16623
Coldn's Avatar
Hot Bodies have release a whole load of new products for their main line of competition chassis’ but we will start with the Cyclone TC. Now you can adapt your Cyclone and Cyclone TC chassis to LiPo power with this LiPo battery upper deck conversion set, which comes complete with upper deck, aluminium block and all the necessary hardware you will need to get up and running. New rear 0º degree hubs have been machined from billet aluminium and anodized purple for added durability and custom looks. Some new aluminum front spindles are more than just aesthetic, but also stronger and more precise on the track. Finally for the TC are the DCJ drive shafts, that maintain better corner speed while drastically reducing wheel chatter. The DCJ or (Double Cardan joint) shaft breaks the single pivot point into two pivot points resulting in less drag and shallower shaft angles during sharp turning.
font: redrc.net
Coldn is offline
Old 06-20-2009, 01:17 PM
  #16624
I wonder what the spacer is for
Lazer Guy is offline
Old 06-20-2009, 01:37 PM
  #16625
I think you need the spacer if you're running the Brushless Motor-Mount which has a 2mm higher Layshaft position.
I'm wondering if it's a real benefit running an unsymetrical topdeck or if it's only needed to make "high" LiPos fit. I have no problems fitting a SMC 4700mAh 40C LiPo into an original Cyclone.
Perhaps anyone from Team HotBodies could answer the question. Thanks!
bonda is offline
Old 06-20-2009, 02:32 PM
  #16626
font: redrc.net
With the new upper deck and aluminium block, what would be the clearance from the surface of the chassis? I am trying to figure out what kind of lipo packs could fit.
billythekid is offline
Old 06-20-2009, 02:36 PM
  #16627
Scott B's Avatar
Trader Rating: 47 (100%+)
It should be the same as it is with the current topdeck, just minus the right middle bulhead that goes over the battery.
Scott B is offline
Old 06-20-2009, 04:11 PM
  #16628
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Waitting release !
RC MARKET is offline
Old 06-20-2009, 05:11 PM
  #16629
Trader Rating: 14 (100%+)
when are they going to be released?
DG Designs is offline
Old 06-20-2009, 10:31 PM
  #16630
bydand53's Avatar
Originally Posted by Korey Harbke
Also check your hinge pins... I've had some people come up to me complaining about the same thing and they had a bent hinge pin.
You nailed it, it was a bent hinge pin !
bydand53 is offline
Old 06-20-2009, 10:43 PM
  #16631
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
See!!! I'm good for something
Korey Harbke is offline
Old 06-21-2009, 07:23 AM
  #16632
jag88's Avatar
Originally Posted by RC MARKET
new option parts
Korey, is this the new top plate that you were testing ?
If so is there any change in handling ?
jag88 is offline
Old 06-21-2009, 04:39 PM
  #16633
Indeed it is. I haven't noticed any change in handling, but I did notice it tends to tweak a tiny bit easier. Other than that, it's great. I've been running it for a while now with good success. It sure makes fitting lipo batteries a lot easier. I'm running a Thunderpower 40C 5000mah battery with a PPD Billet Lipo weight plate and still have room to go.
-Korey
Old 06-21-2009, 10:38 PM
  #16634
RC MARKET's Avatar
Not have special feel !
steering first respond more direct ,
because steering arm shorter.
Old 06-21-2009, 11:56 PM
  #16635
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Do you have one?
BlackedOutREVO is offline
