8T 2.0
#1936
Try searching for one of those online nuts/bolts/screw stores on google. You can get sets of screws and nuts in bulk and keep them around for your next build. I cant remember the one site a buddy told me of. But im sure you can find those bulk places on google.
#1939
pulled front end off new race roller today to put 1.0 servo saver spring on......good thing I did, as there was no "saver" to it....I even tried adjusting just to see if some could be worked in........nothing.......put 1.0 spring on......dialed......one less prob to worry about.......also swapped shock ends and I have modded spindles and hubs coming from JDuB, also got the longer screws for camber links and wingstay @ LHS I Just need to go pick them up, Fresh new Fastlane wrap from my homie Chad B for stock lid/wing, Losi alu steering servo arm, DE skids F/R, new Novarossi plus 4 be here next week ready to drop in and racetune as well from Houston.....I am going to run box stock fluids for its first outing at the track, everything felt pretty good and nothing was leaking.
#1941
#1942
#1943
I took my new truggy out tonight, I am pleased with almost everything, after 2 laps a shock end tore out, then I replaced it and went back out later. Drives well, but it is making bad gear noise, the mesh is good, I'm hoping it is just the ring and pinion mesh breaking in, anyone else having this noise?
Also, is anyone else running an RB WS7III? What clutch combo are you running, mine seems a little weak on the low end with the stock clutch setup.
#1945
#1946
#1948
I also ran mine for the first time on the track last night. It was also making the gear noise. I didnt quite know what it was. Is this something to be concerned about? My 1.0 didnt make this noise. The thing ran great though ,shock ends stayed in tact right out of the box, but I will swap them out before I race. Definately turned better than the 1.0, but will take a little getting used to.
#1949
It could also just be breaking in. Most likely the noise will go away once it wears in. you can get it at auto parts stores in bulk or
http://carolinasrc.com/Webstore/Scri...dproduct=12047
