GRP... Engine... Thread...
#1216
I was with Stipres yesterday, and helped tune it a bit. I have to say that I was boggled also. I have some experience tuning the the GRP since I ran one the majority of last season.
We had it running good during qual's. When it came to the main (even during warm up) it sounded rich going down the straight. Leaned it out (HSN) just before the start, and sounded good the first couple times passing pit lane. The rest of the 20 minutes, it was inconsistent ever pass. I could hear it building up around the track, then by the straight, it would be loaded with fuel, then sound great the next lap or so... then just to hear it building again, then boggy down the straight. After 20 minutes, came in at 178ish. Weird!
All good ideas. He will have to check those things, and seal the engine. It may juts come down to a bad plug or something simple like that. I have had brand new P3's be faulty. We will see.
#1217
The head on the grp .21, (non-tuned version) the silver one, looks alot different than others. It looks like a solid piece of aluminum with just some ridges cut around it. Why is it different than others and is it a big deal as far as cooling ? can it be changed or does it need to be ? sorry for all the questions, Im just trying to learn as much about it as possible before I buy it from amain.
#1218
#1219
any1 have any ideas... i had my grp out this weekend and i did post that it was runnin rich but still hot. i was gettin passed on the straight and i barley could make some of the jumps, some of them not at all.... i ran my dads 8ight after the races and he has his vspec in that has prob 5 gallons or so on it and that thing had 3x as much power and speed as my grp. im going to switch to a p4 plug and test for air leaks. this motor has maybe 2.5 gallons on it, is there a way to test the tank?
#1220
on a decent tune mine runs in the 160-190 range on temps ..all types of power to spare all across the board ....and for all you tune to temp ding dongs ...no i dont tune to temp ...im just saying thats what it temps on a good tune ...so shut it
#1222
i hope they work well ...they should ..they seem to be the best bearings out there ....i would imagine they would hold up better than stock ...tko says they will
#1224
Originally Posted by [email protected]
Hey guys where would I get some orings just in case mine go bad. Mine is still basically ne (just over a half a gallon but I would like to have them just to be sure??
http://www.amainhobbies.com/product_...ducts_id/23854
#1225
What size bearing does the tuned take front & rear?
#1226
Rear Crank bearing 14 x 25.4 x 6
http://tkocompetitiondev.com/product...roducts_id=157
Front Crank Bearing 7 x 19 x 6
http://tkocompetitiondev.com/product...roducts_id=156
#1227
it seems if you have a non tuned version ...you cannot put the tuned (orange head on it) the head on the non tuned is fine and you will save money on glow plugs ....awesome motors tuned or non tuned ....check out www.powerhousercperformance.com ......i believe mark still has some non tuned versions with his race port on them for 260.00 i believe frank l up there runs marks motors ...as do i ...they are awesome and for 60 bucks more than amain ...you will get a motor that will perform as well or better than the tuned version .....
You CAN put the tuned head on the non tuned motor. All you need is the turbo button head, and the orange head bolts right up.
#1228
one thing i have worked out now on these mptors is how important clutch set up is my grp i wasnt happy with the bottom end power leading up to jumps out of corners worked on clutch set up and now has all the power i need motor ran awsome at the national titles
2Likes
