Like Tree2Likes
GRP... Engine... Thread...
Old 03-22-2009 | 11:48 AM
  #1216
Frank L's Avatar
Originally Posted by itsshemp
I was with Stipres yesterday, and helped tune it a bit. I have to say that I was boggled also. I have some experience tuning the the GRP since I ran one the majority of last season.
We had it running good during qual's. When it came to the main (even during warm up) it sounded rich going down the straight. Leaned it out (HSN) just before the start, and sounded good the first couple times passing pit lane. The rest of the 20 minutes, it was inconsistent ever pass. I could hear it building up around the track, then by the straight, it would be loaded with fuel, then sound great the next lap or so... then just to hear it building again, then boggy down the straight. After 20 minutes, came in at 178ish. Weird!
All good ideas. He will have to check those things, and seal the engine. It may juts come down to a bad plug or something simple like that. I have had brand new P3's be faulty. We will see.
I had an issue yesterday with my GRP it would run great and then it was like someone flipped the switch to off and it dies. I changed plugs, had a pro help me with the tune change fuel and then even pull the engine and put in another GRP it still did it. I ended up changing the tank and fuel line and the problem went away. I prob should have done this first but the line was new and the tank had maybe a gallon on it. You just never know. As far as inconsistent tune the o-rings in the needles do go bad. I have seen fuel pool up and come out of the HSN because of bad o-rings. I have seen the idle screw change while the engine was idling because of bad o-rings. The o-rings on this engine need to be replaced periodically. When the needle turns too easily after the engine is warm, it's time to change the o-rings. I also seal the carb and back plate just as a precaution, never had a prob with it but don't want to either. I seal up every engine before I even start to break it in. Saves the annoying air leak tune chasing. GRP's are a good engine but the o-rings seem to get hard after 4-5 gal and need to be replaced. Same thing with the o-rings in the FLS pipe. When they are hard the pipe leaks and time to replace them.
Frank L is offline
Old 03-22-2009 | 12:11 PM
  #1217
The head on the grp .21, (non-tuned version) the silver one, looks alot different than others. It looks like a solid piece of aluminum with just some ridges cut around it. Why is it different than others and is it a big deal as far as cooling ? can it be changed or does it need to be ? sorry for all the questions, Im just trying to learn as much about it as possible before I buy it from amain.
roadracer43 is offline
Old 03-22-2009 | 12:53 PM
  #1218
it seems if you have a non tuned version ...you cannot put the tuned (orange head on it) the head on the non tuned is fine and you will save money on glow plugs ....awesome motors tuned or non tuned ....check out www.powerhousercperformance.com ......i believe mark still has some non tuned versions with his race port on them for 260.00 i believe frank l up there runs marks motors ...as do i ...they are awesome and for 60 bucks more than amain ...you will get a motor that will perform as well or better than the tuned version .....
zixxer is offline
Old 03-22-2009 | 01:07 PM
  #1219
losi_racer's Avatar
any1 have any ideas... i had my grp out this weekend and i did post that it was runnin rich but still hot. i was gettin passed on the straight and i barley could make some of the jumps, some of them not at all.... i ran my dads 8ight after the races and he has his vspec in that has prob 5 gallons or so on it and that thing had 3x as much power and speed as my grp. im going to switch to a p4 plug and test for air leaks. this motor has maybe 2.5 gallons on it, is there a way to test the tank?
losi_racer is offline
Old 03-22-2009 | 01:13 PM
  #1220
i mean does it have compression ? i mean if you are chasing other probs and tuning to your other issues ..its not out of the realm of possibility that your motor doesnt have good compression ...my buddy tuned to the dreaded AE gas tank issue and his was toast in 4 gallons ...im just sayin ....its possible ....but ya air leaks and stuff in the carb or fuel delivery system can cause you some strange probs ...god forbide you have run the motor at high temps ...then your really toasty
on a decent tune mine runs in the 160-190 range on temps ..all types of power to spare all across the board ....and for all you tune to temp ding dongs ...no i dont tune to temp ...im just saying thats what it temps on a good tune ...so shut it
zixxer is offline
Old 03-22-2009 | 05:58 PM
  #1221
hey guys i am looking at putting tko's in my GRP and was wondering for those who have run them for a while how they are holding up? Thanks!
Fierle03 is offline
Old 03-22-2009 | 06:20 PM
  #1222
just put tko's in mine after 1 gallon on the stockies ....hopefully i wont have to answer that question i hope they work well ...they should ..they seem to be the best bearings out there ....i would imagine they would hold up better than stock ...tko says they will
zixxer is offline
Old 03-22-2009 | 06:23 PM
  #1223
Hey guys where would I get some orings just in case mine go bad. Mine is still basically ne (just over a half a gallon but I would like to have them just to be sure??
rgrassey@me.com is offline
Old 03-22-2009 | 06:29 PM
  #1224
Djballen's Avatar
http://www.amainhobbies.com/product_...ducts_id/23847
http://www.amainhobbies.com/product_...ducts_id/23854
Djballen is offline
Old 03-22-2009 | 09:03 PM
  #1225
Frank L's Avatar
What size bearing does the tuned take front & rear?
Frank L is offline
Old 03-22-2009 | 09:32 PM
  #1226
Djballen's Avatar
Rear Crank bearing 14 x 25.4 x 6
http://tkocompetitiondev.com/product...roducts_id=157
Front Crank Bearing 7 x 19 x 6
http://tkocompetitiondev.com/product...roducts_id=156
Djballen is offline
Old 03-22-2009 | 10:57 PM
  #1227
You CAN put the tuned head on the non tuned motor. All you need is the turbo button head, and the orange head bolts right up.
LosiMadMan is offline
Old 03-23-2009 | 02:47 PM
  #1228
mattwoodcraft's Avatar
one thing i have worked out now on these mptors is how important clutch set up is my grp i wasnt happy with the bottom end power leading up to jumps out of corners worked on clutch set up and now has all the power i need motor ran awsome at the national titles
mattwoodcraft is offline
Old 03-23-2009 | 02:49 PM
  #1229
i hear Mario Rossi has now left grp so the question is what will the motors be like from now once all the grp tuned ones have gone ???????
Old 03-23-2009 | 03:25 PM
  #1230
rcboxer's Avatar
Curious, what carb insert you guys running in the tuned .21 for truggy.
rcboxer is offline
