Like Tree195Likes
Novarossi engines thread
Old 02-27-2009 | 03:27 AM
  #3091
Riketsu's Avatar
Hey guys... Im wondering if anyone knows where can I get the underhead gasket that the 353 and the Nova 12-SCT has?
This is the part:
NOVAROSSI O-Rings (1pcs) for underhead [29602]
The only place I have seen it in stock is www.the-border.com... I was wondering if anyone has seen it in a USA or HK shop... Border shipping is $15 for just this oring... Thanks in advanced.
Riketsu is offline
Old 02-27-2009 | 03:36 AM
  #3092
JetMD's Avatar
This is the part:
Check with Robert at Ashford Hobbies. He was able to find a bunch of o'rings for me for a carburator. I would think he'd have no problem getting that one. If it's not on his website, just email or call him and tell him what you're looking for and he can probably get it. Hope that helps.
JetMD is offline
Old 02-27-2009 | 10:04 AM
  #3093
Why not give Jim Hottinger at Fusion Motorsports / NovaRossi USA a try??
Rick Davis is offline
Old 02-28-2009 | 07:43 AM
  #3094
Riketsu's Avatar
I already sent a message through Novarossi USA... Haven't received a reply yet... I really want to buy it from them because I have a few other things I would like to purchase at the same time.
Riketsu is offline
Old 03-02-2009 | 10:27 PM
  #3095
NiTrO BoOsTeR's Avatar
Hey, just got a quick question. I got a Novarossi 3SCT-Tuned and it has had about 2-3L through it, includes Break in and 2 race meets, and i was checking the rod for play and there still isnt any but should i change the rod, im asking this because i dont know if the break-in damages the rod or weakens it.
Mitchell
NiTrO BoOsTeR is offline
Old 03-02-2009 | 10:36 PM
  #3096
Riketsu's Avatar
Originally Posted by musti72
Hi everyone,
I have recently purchased two plus 12-3sct's from my lhs. I opened them for checking the internals, and;
saw some tiny spots on top of piston in both of them
a slight stratch on the side of the piston, and slightly gritty feel on the front bearing in one of them.
these things I have mentioned are very little, but I got nervous.
their production year is 2007.
Can they lead to an issue in future? Im going to use them in nationals this year.
Sorry for bad english...
thanks for the replies.
Dont fire them up... Take them back to your local hobby shop and show that to them.
Riketsu is offline
Old 03-03-2009 | 01:00 AM
  #3097
stefan's Avatar
Mitchell
I would just change it.
When you have play in the conrod, it's actually too late. The "wobbling" rod will wear out your crank pin quickly.
Also, the condition of a rod is not really visible by the fit of the lower journal.
The metal of the rod can be weakened and make it break.
I would rather change it and be on the safe side.
stefan is offline
Old 03-03-2009 | 01:57 AM
  #3098
mick8488's Avatar
Default nova engines
Guys,
Been running nova engines for a while now, and I've never had to change the conrod in them. In my experience, the bearings will wear out first before you need to replace anything. By that stage, it's probably cheaper buying a new one anyway. Re: 2630 pipe. Maybe a little thirsty, but I can still make 5 mins easy on a big track (Brendale, Australia) with a Plus12-3sct Tuned, even more on my smaller home track. The stock 07 353 will give you incredible mileage, but I prefer the 3sct. More grunt, and top end is just as good. However, the 353 09 looks pretty trick.
Mick
mick8488 is offline
Old 03-03-2009 | 01:59 AM
  #3099
yea i thought so, thanks for the advice
Old 03-03-2009 | 05:17 AM
  #3100
J.Gonzalez's Avatar
Default Piston and sleeve question
I was looking on novarossi website for part numbers for replacement piston and sleeve for r1wsc2008 motor and it appears that all the parts are exactly the same as the 321p motor except the piston sleeve part number
Same crank,bearings, connecting rod, case, button etc.
Looks like the 321p is an 8port motor versus 7port for wcs.
What is everyone experience with the 321p looks to be a couple years older?
Would you consider the swap to 321p p/s?
Jamie
J.Gonzalez is offline
Old 03-03-2009 | 05:43 AM
  #3101
nytaurean's Avatar
Default 321
Hey Jamie:
You can't go wrong with the 321 motor it's excellent! I have ran a few over the years and they are very powerful. They have lots of torque and midrange. You will be very happy with this piston and sleeve replacement!
nytaurean is offline
Old 03-04-2009 | 12:52 AM
  #3102
RC MARKET's Avatar
Sorry
i'm don't know NOVAROSSI
353 Turned & Race 09 what different ?
which one best ?
Thankyou !
RC MARKET is offline
Old 03-04-2009 | 04:36 AM
  #3103
bigredspeed's Avatar
Originally Posted by gearhead_22
what's up guys I have a 35plus21. Has less than a gallon including break in, and the piston looks like this is that ok.
wow, thats Black, you must have tuned the motor to race speck, cause if thats only running in, then that piston should be still shinny, what your piston looks like there is how my pistons look after a big race event not when im running a motor in. see if the black carbon on the Piston just wipes away with a rag, if it dose then you are using a good quality fuel, if it needs polish to remove, then the piston is running dry and the Caster in the fuel is baking on the Head of the Piston.
bigredspeed is offline
Old 03-04-2009 | 10:37 PM
  #3104
rc-campus's Avatar
Thumbs up
I saw all new engines are available now.
353-09 $399.99
rc-mushroom.com/product_info.php?cPath=169&products_id=16558
Flash 21 $649.99
rc-mushroom.com/product_info.php?cPath=169&products_id=16554
Flash 21 tuned $725
rc-mushroom.com/product_info.php?cPath=169&products_id=16555
N12 $120
rc-mushroom.com/product_info.php?cPath=169&products_id=16559
rc-campus is offline
Old 03-07-2009 | 12:45 PM
  #3105
Hi there!
I have two unused engines here:
35 plus 21 Collari
and
Collari Cordoba version
Are they similar in performance or is one more biased on torque and the other more on revs? Which one is better for a track with a very long straight?
Thanks for your feedback!
fulcrum2 is offline
