PICCO P9 EVO 2
#123
hi guys, i finally got my hands on the P9 for my 960, i have a question regarding parts for this engine. what other brand's conrod i can replace it with if i need replacement? from what i remember the Mega DSII, and the IDM is based on the P9 (P7R), but are there any difference in terms of the conrod? can you provide the part number and also where to get one from?
thanks
thanks
#125
thanks duneland, do you or anyone else knows the part number for IDM compatible conrod for this engine, if it's compatible? just want to know my other choices. also, whenever the conrod is replaced, is it a must or preferable to change the piston pin and the spring thingy that holds the piston pin?
thanks
thanks
#126
Yes, replacing the Wrist pin and clips are recommended when replacing the connecting rod.
#127
thanks
thanks
http://web138.sydney.webhoster.ag/sh...4a1auiqdil30c2
#128
Has anyone ever notice circular scratches on the backplate of the P9? I noticed scratches which are also wearing away the black coating on the backplate. I asume that this is from the con-rod, yet the con-rod appears to be ok. I suspect that the bearings may have some play or should I not be concerned. Any suggestions?
Thanks in advance.
Ken
Thanks in advance.
Ken
#129
Thanks in advance.
Ken
Thanks in advance.
Ken
That's normal. Nothing to worry about.
#131
#132
Just picked up a P9 Evo 2 and was wondering about the plug.
When I looked for plugs I noticed that the #7 plug comes in both a long body and a short body (at least from nova).
Can someone tell me the correct plugs I should order.
#133
There is only one #7 PICCO plug which is a cold plug, use only PICCO PLUG is the correct plug, you can click the web link on my signature and order PICCO Plug from the website.
#135
