Old 08-14-2007, 04:23 PM   #91
Team Kamikaze's Avatar
Originally Posted by RC-ProSpeed View Post
what header and pipe do you guys recomend for this engine to run on a big track?....(301 raceway)
The 2033 pipe and Conical header set runs good with this engine at 301 raceway, we have personally tried it during the capitol classic race last June,
we also tried the 2015 pipe with the PICCO conical header which gave us a little bit more top end, and we also tried the 2052 with a medium Nova Rossi conical manifold, it creates a lot more power but runtime was cut short,
2033 pipe set = good bottom end and making barely 5 minutes
2015 w/ PICCO conical manifold =more top end making 5 minutes
2052 w/ med NR Conical manifold = broader power band 4 to 4 1/2 mins. runtime
2052 w/ long NR Conical manifold = more bottom less top still less than 5 mins runtime
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-15-2007, 06:30 AM   #92
RC-ProSpeed's Avatar
Thanks for the detailed information, helps a lot, due to the fact that I had problems before with other engines with ruin time.
Are you coming for the I95?
RC-ProSpeed is offline   Reply With Quote
Old 08-16-2007, 10:26 PM   #93
Unfortunately no, but will probably go to the 301 Capitol Classic next June.
Old 08-17-2007, 05:56 PM   #94
lastsun's Avatar
when switching fromm picco 2033 to nova 2052 pipe are there much tuning to the needles needed?????
Serpent 966 EVO / OS MAX
lastsun is offline   Reply With Quote
Old 08-17-2007, 06:11 PM   #95
Depending on the size of the header, which normally is a medium conical, you will need to richen the HSN to about 3 hours, also it will depend on what fuel you are using, to be safe I would richen it to about six hours, run for about 5 laps bringing the engine temperature up then tune it from there on.
Old 08-21-2007, 12:35 AM   #96
How about the life span of this engine? I heard that picco engines are very
fast but the life span is short compared to nova's. The pinch goes easly away. Is that true? (Considering normal racing use)
deepfree_z is offline   Reply With Quote
Old 08-21-2007, 04:11 AM   #97
quietstorm76's Avatar
I have Piccos that have NO!!! pinch at all and it still runs. Cranks easy and still makes a lot of power. As far as lasting, I have a Mega/Picoo DSII .21 that has 7 gallons thru it and it's still fast. I just change the rod every 2 gallons.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-21-2007, 10:55 AM   #98
duneland's Avatar
Over the years (quite a few), I have found Picco engines to have very high quality materials and longer lasting than most. Carbs are often a problem, but not the engine itself.
Pinch means nothing. Compression is very important though. Off-road, I have gotten in excess of ten gallons through piccos. On-road is much tougher on engines though.
duneland is offline   Reply With Quote
Old 08-23-2007, 01:48 PM   #99
And the runtime on this engines are great.
Old 08-23-2007, 09:43 PM   #100
Maximo's Avatar
I am sorry to go OT here... But i am having a problem with one of my modded Picco's. I am running a modified P7 EVO 2, modified with advanced transfer timing and a 8 degree increase in rotor closing.... Anyways it seems my RPM tends to race when i let off the throttle...its especialy annoying when i am trying run smooth over the jumps.... The motor is acting like its lean on the LSN, but i have it running pretty dam rich on the needles..... I have even installed double sealed ceramic front bearing, I have sealed my needles, i have smoothed my carb slide, installed a strong TRS.... I am stumped, I beleive my head clearance is set to .027 " , i am running a OS P7 med plug, 086 tuned pipe... I am fairly new to Picco engines, and this has me stumped, i have done everything i can think of to no avail....
Maximo is offline   Reply With Quote
Old 08-24-2007, 07:43 AM   #101
Sounds like your LSN is too Rich, try leaning it out.
or maybe the modification might have hurt the tunability of the motor......which is possible.
Old 08-24-2007, 09:12 PM   #102
Maximo's Avatar
well it appears my front bearings seals are shot. She's leaking fuel like a fawcet..Unfortunately this bearing is a aftermarket ceramic bearing....I wont say what manufacturer till they have a chance to fix the issue... My original issue was a hanging throttle slide, it mimicked an airleak, so i replaced the front bearing ... I also fixed my sticking carb, but my new bearing must have been leaking right off the bat.......Anyways I re-installed the facotry bearing and the motor is running like a champ..... Extremely powerful for a .21, i am very happy with the P7's power...
Old 08-24-2007, 11:27 PM   #103
I'm glad you figured out.
Old 04-09-2008, 05:07 PM   #104
Default Plugs
Any recomendations for plugs to use with thi engine?
Picco are not that easy to get around my area.
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
Old 04-12-2008, 11:51 AM   #105
PICCO P7TC Turbo Cold plugs or MEGA # 200171 Turbo 7 Cold.
F/S Picco JLR red dot.12 with 2607 picco pipe entitymugenmtx R/C Items: For Sale/Trade 5 01-31-2008 01:08 AM
picco p3-28 --- picco p7-r .21 --- jp3 p/h --- dynamite mach .28 for sale will g R/C Items: For Sale/Trade 9 07-27-2007 11:00 AM
JLR .12 Red-Dot Picco vs Z.12R Team Spec.3 vs Picco (#P1-4073) P1-R .12 RE EVO 3 Tur nickiphorosn Onroad Nitro Engine Zone 11 04-13-2007 10:18 PM
Is the OFNA Picco .27 and the Werks Picco .27 Identical? Chase Electric Off-Road 1 01-06-2006 01:09 AM
Trinity/Picco .12 RE, with Picco manifold, NIP sac R/C Items: For Sale/Trade 2 06-13-2003 09:07 AM
