PICCO P9 EVO 2
#62
Originally Posted by Wanabrc
Well I was finally able to confirm (without the help of anyone on here) that the P9R is very similar if not the same as the mega zx line. The piston and sleeve are the same but I am unable to measure crank timing.
Originally Posted by gashuffer
Whats a good pipe to run with this engine?
I ran my Mega DSII engine's with the 2018 and 2033 exhausts, but after trying the 2052, even more power comes alive....
#63
I had to find out by purchasing one and comparing it to my friends mega zx21 but thanks anyways. I don't know why some people avoided answering the question.
#67
Originally Posted by Team Kamikaze
Run it at .60mm shim if running 30%.
You should run the engine with .6mm of head clearance.
To measure your head clearance, you can do the solder test, or put the piston in TDC, unscrew the head and head button, and measure the distance from top of piston to top of liner. (remove all shims)
Also measure (again, without the shims) the depth of the head button. These 2 figures should give you the headclearance without any shims.
#68
Originally Posted by C Verano
So far here in Las Vegas the motor has been running very well. In this higher elevation (2000 ft ) the motor has been running in the 225 range with .40 mm of shims and 30% O'Donnell. With the Picco 2033 pipe and conicle header the motor has very good bottom and the top end is also very good. We should be running the "A" main in a few hours. I'll let you guys know how it goes.
What is the OFNA part no. for the Picco 20033 pipe and conical header?
#69
Originally Posted by dougday
Chris,
OFNA has not decided to bring any pipes in yet. In the mean time you can go with the Serpent Mega 2033 (part #203045). You can check it out here...
http://www.serpent-usa.com/es1024768/index.htm
Chris
#70
Doug,
Chris
Chris
#71
Doug,
Chris
Chris
#72
If this engine really is the same as the Mega ZX, then run it with the 6 fins header and Novarossi 2052 pipe... you will be even more pleasantly surprised...
I ran my Mega DSII engine's with the 2018 and 2033 exhausts, but after trying the 2052, even more power comes alive....[/QUOTE]
I tried the 2052 pipe/header combo this past weekend and it was amazing. I've ran my DSII for about 5 or 6 months now with the 2033 and had no complaints but the power from the the 2052 is very surprising. Try it.
#73
#74
C Verano,
Thanks for hooking me up this weekend at Crystal Park Raceway. The engine woke up and the car runs on rails. Now thats what I call customer support!!!!
#75
Thanks guys. I have the 2052.
