Old 01-30-2009, 12:17 PM   #136
Trader Rating: 4 (83%+)
Hey Sam, sorry he is a very busy man he has no time for his freinds right no jejejej, please send it to me .
Roniel_R is offline   Reply With Quote
Old 01-30-2009, 12:27 PM   #137
tdr170's Avatar
Questions??
Sirio S7 Turbo Buggy Glow Plug
So these plugs will work just fine. I have a credit at a hobbie shop and they carry these.
Mugen MRx4X - Picco P9 EVO 2
Thanks for your replies
tdr170 is offline   Reply With Quote
Old 01-30-2009, 12:46 PM   #138
Sorry not the buggy you need these/S001720127
Old 01-30-2009, 01:56 PM   #139
tdr170's Avatar
Questions??
Kamikaze
You are comming to the Winter Nats will you have items for sale there such as the picco plugs. I just picked up a Mugen from someone I think you know (Brian Nak-----).
One more question there is a ofna starter box I can pick up for a good price see pic is this a good box for my needs.
Mugen MRX4X - Picco P9 EVO2
Old 01-30-2009, 02:50 PM   #140
M7H
M7H's Avatar
Originally Posted by Team Kamikaze View Post
There is only one #7 PICCO plug which is a cold plug, use only PICCO PLUG is the correct plug, you can click the web link on my signature and order PICCO Plug from the website.
Excuse me? Cold plug only?
Cold: P7TC
Hot: P7TH
Maybe you don't have them in your store, but this doesn't mean they don't exist
And I would recommend GRP or Sirio plugs over original Picco plugs for the simple reason, that Picco plugs aren't the best at this moment, just like Novarossi is also poor quality....
Yes, Picco/GRP/Sirio, are exchangable....
Oh, another reason, they cost way less then Picco....
Serpent
M7H is offline   Reply With Quote
Old 01-30-2009, 03:27 PM   #141
tdr170's Avatar
Questions?? Plugs
Ok I found the Sirio plugs at ashford hobbies for 6.75. (1720127)
The GRP plugs I could not find for less then 11.75.
Kamikaze sells the picco plugs for 8.50.
M7h if you know of a better deal please tell us.
Old 01-30-2009, 03:37 PM   #142
you should be ok with the Sirio ,i would recommend not using the GRP plugs on the Picco engines they dont seem to seal properly on the head button..
Old 01-30-2009, 04:17 PM   #143
tdr170's Avatar
Thumbs up Plugs
Thanks I am going to order a few. I dont understand the statement about the p7th and p7tc I always thought the # indicated the temp.
Then I looked at some Kyosho plugs while I was browsing and found they had plugs markes S09 hot and S09 cold.
Does anyone have experience with the starter box i showed a few columns down will this work for me ofna10250.
Old 01-31-2009, 01:25 PM   #144
M7H
M7H's Avatar
Not in my experience, they work perfectly....
Actually, Serpent teamdrivers running the Mega engines last year (like I did), recommended them to me....
About the price for GRP plugs, here in the Netherlands I can buy a set of 5 GRP plugs for 32 Euro, while 1 #7 Picco plug will cost me 9 Euro....
Serpent
Old 02-07-2009, 08:46 PM   #145
tdr170's Avatar
Questions?? P9 EVO 2
Ok I now have the P9 and I was wondering about a few things.
As this motor was used when I got it I wanted to go thru it (piston and sleeve are new).
I pulled the motor apart and went ahead and replaced the outer bearing since I had one but no matter how much I heated I could not get the inner bearing out (any thoughts). ???
Secong was the head shim it measured .49 does anyone no what the shim would be for 20-25%?
I was told they had it set for 30%.
The motor by the way is in great shape with lots of compression tight fit crank to rod (also have extra rod).
Old 02-09-2009, 05:53 PM   #146
tdr170's Avatar
Default P9 EVO 2
Ok I got the inner bearing out today I guess I did not heat it enough before.
I still am looking for the head shim size.
Old 02-10-2009, 03:35 AM   #147
M7H
M7H's Avatar
The best is the following:
Put piston at TDC, and then unscrew the cooling head and headbutton.
Measure the distance from top of liner to top of piston.
Also measure the distance the headbutton goes into the liner.
The difference (head clearance) should be around 0.2mm, but I have seen headbuttons where this distance is 0mm.
Now shim the headbutton, until the head clearance is 0.5 - 0.55mm for 25% Nitro, at sealevel...
Serpent
Old 02-10-2009, 10:48 AM   #148
GREGORY!'s Avatar
M7H you are talking about the squish right?to make it around 0.5-0.55.
i have seen that a lot of ppl take this numbers as standard.[i have seen the same numbers for novas.
but i dodnt think that they will have the same compration.i mean different cc in the buttons.
what do you think?
GREGORY! is offline   Reply With Quote
Old 02-10-2009, 02:04 PM   #149
M7H
M7H's Avatar
Nova's are more in the range of 0.6-0.7mm, Picco's are between 0.4 and 0.6....
That is indeed the difference in headbutton volume....
squish??
never heard of that word, in this context.... but if you say so?...
Serpent
Old 02-10-2009, 03:27 PM   #150
tdr170's Avatar
Thumbs up Shims
Thanks M7H for the help I took the head off and measured both the piston to top of cylider and the depth of the button.
The piston to top of cylinder is 3.33mm and the button was 3.14 to equal a .19 clearance so I will need a .31 shim to be at .5.
As you can see the button on my Picco is 3.33 not the .4-.6 you descibed not sure why.
But thanks again.
F/S Picco JLR red dot.12 with 2607 picco pipe entitymugenmtx R/C Items: For Sale/Trade 5 01-31-2008 01:08 AM
picco p3-28 --- picco p7-r .21 --- jp3 p/h --- dynamite mach .28 for sale will g R/C Items: For Sale/Trade 9 07-27-2007 11:00 AM
JLR .12 Red-Dot Picco vs Z.12R Team Spec.3 vs Picco (#P1-4073) P1-R .12 RE EVO 3 Tur nickiphorosn Onroad Nitro Engine Zone 11 04-13-2007 10:18 PM
Is the OFNA Picco .27 and the Werks Picco .27 Identical? Chase Electric Off-Road 1 01-06-2006 01:09 AM
Trinity/Picco .12 RE, with Picco manifold, NIP sac R/C Items: For Sale/Trade 2 06-13-2003 09:07 AM
