Go-Tech Engines Thread
#4981
If you don't have the correct puller or installer, the oven trick is the best way. here are the sizes you need
Rear...14x25.4x6
Front....7x19x6
#4982
Thanks, but are you sure those are the ones for my GO .21 5pt ?
The reason I ask is because I read a review on those same bearings and a guy said he bought them for his GO engine and they did not fit/work properly and I don't want to make the same mistake.
Thanks again.
Thanks again.
#4985
I was breaking in my 3-port sport today...first break in I have ever done. I was using a combination of the heat cycle method and the instructions that came with the engine. Unfortunately, the engine was much too cool - around 160 degrees. I have only idled my way through three tanks of gas so far, no real throttle yet, and no driving it around on the ground. LSN was flush, HSN was about 2 turns out from flush which is probably what contributed to the ultra-low temps (That and no foil around the head).
Have I already screwed my engine forever, or if I make sure that the rest of the break in takes place around 220-240 degrees or so will that help? I still have about 10 tanks to run through it as I slowly lean the engine out to make power.
I guess I learned my lesson (and found the break-in instructions on page 78 of this thread). Just wanted some input from people who have done this a lot! At least it wasn't some $400 mill, I guess.
Thanks!
Thanks!
#4987
Thanks!
Thanks!
It should be fine; If anything you may wanna replace the rod after about a gallon of fuel, which is not a bad idea to do on any engine after break in. The good thing about the Go's is the rods are only 18-20 bucks.
#4988
I just wanted to get on here and let every go engine user know my expeirence with (22racer) Rex. I bought a worn out go .21 5 pt. from a fellow member and was having problems with it. I sent it to Rex and he put a new rod new boot and pinched it for me. This motor has been spot on. I am so happy with this engine now, it runs like a new engine, and is consitant. I would recommend his services to anyone that needs a pinch. Thanks Rex!
2Likes
