PICCO P9 EVO 2
Old 06-01-2008 | 06:46 PM
  #121
Paul Wall's Avatar
Registered User
so how does the stock version compare to other higher priced brands? just lookin to compete at the club level
Paul Wall is offline
Old 06-02-2008 | 10:24 PM
  #122
Colt4g63's Avatar
Even in stock form this engine is very strong.
Colt4g63 is offline
Old 06-12-2008 | 03:17 PM
  #123
hi guys, i finally got my hands on the P9 for my 960, i have a question regarding parts for this engine. what other brand's conrod i can replace it with if i need replacement? from what i remember the Mega DSII, and the IDM is based on the P9 (P7R), but are there any difference in terms of the conrod? can you provide the part number and also where to get one from?
thanks
amuse is offline
Old 06-12-2008 | 03:23 PM
  #124
duneland's Avatar
DS2 rod fits. I just put one in mine. MEG202170.
duneland is offline
Old 06-12-2008 | 11:28 PM
  #125
thanks duneland, do you or anyone else knows the part number for IDM compatible conrod for this engine, if it's compatible? just want to know my other choices. also, whenever the conrod is replaced, is it a must or preferable to change the piston pin and the spring thingy that holds the piston pin?
thanks
amuse is offline
Old 06-12-2008 | 11:33 PM
  #126
Team Kamikaze's Avatar
Originally Posted by amuse
anyone else know the compatible conrod for this engine, like the part number for the IDM conrod? also, whenever the conrod is replaced, is it a must or preferable to change the piston pin and the spring thingy that holds the piston pin?
thanks
Yes, replacing the Wrist pin and clips are recommended when replacing the connecting rod.
Team Kamikaze is offline
Old 06-12-2008 | 11:55 PM
  #127
stefan's Avatar
thanks
Here you go:
http://web138.sydney.webhoster.ag/sh...4a1auiqdil30c2
stefan is offline
Old 06-24-2008 | 04:58 AM
  #128
kmh
Default picco p9 backplate
Has anyone ever notice circular scratches on the backplate of the P9? I noticed scratches which are also wearing away the black coating on the backplate. I asume that this is from the con-rod, yet the con-rod appears to be ok. I suspect that the bearings may have some play or should I not be concerned. Any suggestions?
Thanks in advance.
Ken
kmh is offline
Old 07-04-2008 | 04:31 PM
  #129
Thanks in advance.
Ken
That's normal. Nothing to worry about.
Brent Davis is offline
Old 07-15-2008 | 12:21 PM
  #130
Does anyone here happen to know if the Mega ZX21 DSII piston/sleeve set can be used in the Picco P9 Evo II engine?
I'm talking about the following part number: MEG202174
Thanks in advance.
Walt is offline
Old 07-15-2008 | 12:39 PM
  #131
Thanks in advance.
Yes it should.
Old 01-30-2009 | 10:31 AM
  #132
tdr170's Avatar
Default Glow
Just picked up a P9 Evo 2 and was wondering about the plug.
When I looked for plugs I noticed that the #7 plug comes in both a long body and a short body (at least from nova).
Can someone tell me the correct plugs I should order.
tdr170 is offline
Old 01-30-2009 | 10:43 AM
  #133
There is only one #7 PICCO plug which is a cold plug, use only PICCO PLUG is the correct plug, you can click the web link on my signature and order PICCO Plug from the website.
Old 01-30-2009 | 10:47 AM
  #134
Like kamikaze said Picco only has one style plug, you can run Picco/Sirio/IDM they are the same tappered conical,wich ever one is easier for you to get..
Roniel_R is offline
Old 01-30-2009 | 10:53 AM
  #135
Roniel.
Did you get the tracking number from Mr. Clean? I sent it to him through PM 2 days ago. Let me know.
