Like Tree2991Likes
1/12 forum
Old 05-31-2008 | 10:03 PM
  #28801
picco007's Avatar
Yes, Yang is correct we run on asphalt here in San Antonio with a approx. 150 foot straight. I ran an 81 mm rollout and it was HOT.....but the temps here are 90+ with track temps approx 120.....I will check to see what I run this weeken, we may have to run a lower rollout......
picco007 is offline
Old 06-01-2008 | 03:51 PM
  #28802
RCSteve93's Avatar
Does anyone know if the Novak XBR ESC will fit under a 12th scale body? It is the same height as a GTB.
RCSteve93 is offline
Old 06-01-2008 | 04:08 PM
  #28803
trailranger's Avatar
XBR didn't fit under my 1:12, So i cut a hole for the Heatsink to poke out.
I have the GTB 4-cell now
trailranger is offline
Old 06-01-2008 | 05:28 PM
  #28804
Ferrarimk13's Avatar
are you able to remove the heatsink or cut it in half? if you cut it, i dont see a problem with heat too much.
Ferrarimk13 is offline
Old 06-01-2008 | 05:52 PM
  #28805
I removed the height sink and made a custom one out of aluminum. looks really factory.
CREWMAN is offline
Old 06-01-2008 | 05:54 PM
  #28806
Scottrik's Avatar
If you're only going to run it 4-cell and know someone with a mill just have 'em buzz the fins off. OR...if you've got a lot of spare time and a Dremel... Mind your fingies though as it'll get HOT while you're grinding.
You need the "plate" that's left though as it is potted to the electrical bits inside and seals the crap out. Won't be enough cooling for 6-cell use after that though.
Scottrik is offline
Old 06-01-2008 | 08:42 PM
  #28807
so everyone is in favor of peeling the top off the orange...
Old 06-01-2008 | 09:50 PM
  #28808
odpurple's Avatar
Yes, before the 4 cell GTB was available I used to take the heatsink off of the GTBs and replace it with an .032" plate. Now you can get the 4 cell version which has an .063" plate, and it works very well. I've never used an XBR but I would expect the same results
odpurple is offline
Old 06-02-2008 | 08:53 AM
  #28809
Those same GTB plates will fit the XBR. Just doesn't use the center screw.
With a little tinkering you can make the XBR pretty thin actually. I cut the pins to make the two boards closer with mine and cut the case all up to make it thinner. Just needs some tape between the boards to keep them from shorting out and it works great for 17.5/13.5 in 12th. Saves about .3 ounces over the GTB 4cell.
Fred_B is offline
Old 06-02-2008 | 11:56 AM
  #28810
nutsisneat's Avatar
Default Futaba FASST with 4.8 Volt
I read somewhere that the Futaba Fasst receivers work only with 6 volt.
Does somebody use Fasst receivers on 1/12 scale with 4.8 volt?
And work the Fasst system with analogue servos such as the Futaba 9602?
Thanks...
nutsisneat is offline
Old 06-02-2008 | 12:00 PM
  #28811
theisgroup's Avatar
Thanks...
works in 1/12 and you can run analog or digital. based on the 3pks' mode (pcm/ppm)
theisgroup is offline
Old 06-02-2008 | 07:08 PM
  #28812
odpurple's Avatar
I've set up numerous cars with the futaba 2.4 ghz system and 9602 servos and they work great. You cannot run in HRS mode with the analog servo, though.
odpurple is offline
Old 06-03-2008 | 01:09 PM
  #28813
losithrasher's Avatar
does anybody forsee a lipo battery being made for the 1/12th scale market?
losithrasher is offline
Old 06-03-2008 | 01:34 PM
  #28814
Lee_123's Avatar
If you mean LIPO saddle packs I think MAXAMPS already has them.
Lee_123 is offline
Old 06-03-2008 | 01:42 PM
  #28815
well it would need to be a battery that comes close to 4.8 volts wouldnt it?
