Like Tree2991Likes
1/12 forum
Old 05-12-2008 | 05:53 PM
  #28666
radio_car_racer's Avatar
Originally Posted by march to my own
The springs will work on any associated dynamic strut FE. It doesn't matter what make of car.
understood,
but I would like to know if anyone is using them and how do they think they compare to the AE springs
radio_car_racer is offline
Old 05-12-2008 | 06:18 PM
  #28667
protc3's Avatar
If it helps any, I have had a bunch of people order them for all brands of cars. They seem to be becoming a very big seller for us. I designed them to enhance the handling of our car but it seems alot of people are liking them on other cars also. I have not personally tried them on other cars, just ours.
protc3 is offline
Old 05-12-2008 | 06:23 PM
  #28668
theisgroup's Avatar
Originally Posted by radio_car_racer
understood,
all in all, they do not collapse like the ae spring and they do seam "softer" then the AE springs. I was running 18AE and went to 20BMI. have 4 solid race days on them and they are the same length right to left. the AE springs were not even the same length out of the package.
theisgroup is offline
Old 05-12-2008 | 07:17 PM
  #28669
RCSteve93's Avatar
I need a set. That has become one of my bi-weekly expenses, new front springs. I hate how you tap the front end barely hard and they your car starts hopping and is all out of wack.
RCSteve93 is offline
Old 05-12-2008 | 09:35 PM
  #28670
boscoj's Avatar
So what's up with the "linear" front springs on BMI's site? Is this implying the stock AE front springs are progressive?
boscoj is offline
Old 05-13-2008 | 02:25 AM
  #28671
protc3's Avatar
The AE front springs are progressive. Our springs are Linear and preset to there length so they will never collapse.
protc3 is offline
Old 05-13-2008 | 04:14 AM
  #28672
sg1's Avatar
sg1
How can I get some of those springs??
-Wayne
sg1 is offline
Old 05-13-2008 | 06:06 AM
  #28673
protc3's Avatar
Give me a buzz bro. I will get some out to you
protc3 is offline
Old 05-13-2008 | 08:02 AM
  #28674
boscoj's Avatar
So are the BMI kingpins larger diameter or just longer?
boscoj is offline
Old 05-13-2008 | 08:14 AM
  #28675
protc3's Avatar
We do offer longer kingpins but our springs work on standard 1/12th kingpins. You will need to remove 2 of the kingpin shims but they will fit with no issues. Our kingpins are standard 1/8th diameter. The springs are a larger diameter and come with spring perches.
protc3 is offline
Old 05-13-2008 | 10:24 AM
  #28676
al dente's Avatar
has there been any talk of battery companies coming out with a lipo equivilant to a 4 call pack for compeative 1/12 racing?
al dente is offline
Old 05-13-2008 | 10:48 AM
  #28677
timmay70's Avatar
People talk about it all the time, no companies talk about it. Unless the voltage gets dropped to nominal 3.7v you will not see Lipo used in 12th scale. At that low voltage (single cell) most people will need to run a receiver pack. If that is the case, how much money are they saving, or how many headaches are they avoiding? Even with a 2s receiver pack, you will need a lipo regulator so that you don't kill your electronics.
With the reduced voltage comes reduced rpm, both directly related...
I like the idea of reduced maintenance in 12th scale, but not the smoke and mirrors kind of reduced maintenance. Receiver packs are just another thing to monitor all the time. This is also an issue for people that want to race World GT, as the rule set for that division is 4 cell NiMH.
timmay70 is offline
Old 05-13-2008 | 11:22 AM
  #28678
with the LRP Sphere 007 you can race 4 cell without receiver battery: no problems at all even with a 4.5 in a 12th scale car.
Frans H is offline
Old 05-13-2008 | 11:30 AM
  #28679
Frans the issue isn't with the ESC it's with the reciever. The Spektrum systems are very sensitive to voltage and if it drops to low it shuts off. At 3.7v the reciever won't even run so you'll need a reciever pack. Other recievers have issues with that low of a voltage as well but the worst is probably the Spektrum.
InspGadgt is offline
Old 05-13-2008 | 12:30 PM
  #28680
al dente's Avatar
timmay - another good point, i have a feeling that the solution lies in the world of li-ion. we will have to see what shakes loose in that feild.
al dente is offline
