Hot Bodies Cyclone
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
the surface was 80 degrees, but it still shoulda been close, the car was scary to drive with the way it would drift.
you guys are both running 1.5mm shims under the blocks? what does it do? Its like 70 degrees here, the tires dont get too hot!
I also shoulda stated im running on my driveway which is completly unswept, and untreated!![EEK!](https://www.rctech.net/forum/classic_images/smilies/eek.gif)
Im just wanted to see what the car would do on assphalt since its pretty dialed on carpet? I was shocked that it would slide like a drift car!
OK I got my winning 13.5 setup from the REEDY Warmup race up on gearchart.com..![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
http://www.gearchart.com/setup/setup...RMUP_SETUP.pdf
Any Questions let me know..![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
Thanks for posting your setup.... I'm going to try it in mod and see how it works for me this Sunday. I know it's for 13.5 but I am using a 4600MM (a little more than a 10.5) to start my asphalt mod season with. My layout has many tight turn, is there something I should change or should I try it like it is first ????
Thanks again
Scott B
Thanks again
Thanks again
Try increasing the ackerman from 2.5 to 4, and or change the front pivot block from the 1 to a 1.5 or 2, try it and see which one works good for you.
Also you could try raiseing the front rear block from the 1.5mm spacer to a 2mm giving the car some anti-dive. I'm going to be trying this change this weekend.
I'm going back to our standard set up. It was consistent and always kept me in the hunt for the win. I tested alot of set up's in two days and find myself sticking with the regular.
what happens when you raise the roll centers?
I would start with thickening your oil, try 45-50wt.
another week and two days and I get to race again......LOL
Also you could try raiseing the front rear block from the 1.5mm spacer to a 2mm giving the car some anti-dive. I'm going to be trying this change this weekend.![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
you're dealing with arm sweep with the front blocks...reducing the track width. usually a narrower track width at the front can make the car feel twitchy.
On the front a higher number pivot block will make the steering a little more aggressive. You shouldnt need it on the Cyclone S as it has more flex than the full cyclone and thus should have more grip anyway.
At the rear 3.0 toe in is pretty standard on the cyclone. As the toe in decreases you effectively get more straight line speed/acceleration, however, as it decreases the car will not hold corners as well.
I find with a 540 motor on asphalt 1.5 - 2.0 is about optimal with stock 2.0-2.5 maybe manageable. After that anything else i would leave at 3.0 including a 13.5 brushless motor.
The sheet doesn't take into account for your 18t center pulleys and it gives the internal ratio of 2.4375 (16/39) instead of the "proper" 2.1667 (18/39)
Sorry man...Just figured I'd let you know
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
inconceivable
I ran the 0* front block on carpet and my car was very twitchy, I added 1mm wheel spacers to make the front wider and my car was not twitchy at all and drove very nice. I had to keep the wheel nuts tight with the 1mm spacers.
Ya I know, I could type in the new D/R in the box put it would just change back to the stock ratio.
![weird](https://www.rctech.net/forum/classic_images/smilies/weird.gif)
![Roll Eyes (Sarcastic)](https://www.rctech.net/forum/classic_images/smilies/rolleyes.gif)
That's why I noted it on the setup sheet.
My final D/R that I ran was 4.6 with a Novak SS pro 13.5. 100/47
