Serpent 720
#3586
#3587
traction and grip
hi guys...sorry if my questions sound silly,
usually when i go to different tracks for racing i will always get early information regarding the track before i arrive. so that makes thing sort of easier to preset the car.
my question here , how do we determine whether d track is at what traction and grip level if we have no info's.
and what is the base setup u guys start with for
1. low traction
2. high traction
thanks
1. low traction
2. high traction
thanks
#3588
1. low traction
2. high traction
thanks
1. low traction
2. high traction
thanks
If you have absolutely no reference, go to the track and sit out first while watching others testing their cars. Then check out the performance, ask what shores they're using ... you don't have to be the first one out on the track right?
#3589
Why dont the serpent diffs have belt guides on both sides??
My rear belt rides only half on the diff, new belt, tightness set at default, and the cams set the same both sides (double checked).
If I move the rear drive gear over so that the belt rides fully on the diff, then I have had the brake disc come uncoupled from the drive pins. If that doesnt happen, the belt falls off the diff.
Has anyone modded a diff with a guide on the other side?
#3592
i qualify on a new set and use fresh set for main....every race...
#3594
but at big races they always has tyres ready for each heats and finals. and like s10dude mention fresh pairs are better if u have the resources. But for budget racers like me, when i practice with new tyres i will keep them when they reach certain diameters that can be used for heats in future races. i keep them in air tight containers. this way i get to practice and already "trued" tyres
#3595
#3596
I've tried the JACO ones on Serpent rims courtesy of Julius a couple of years ago and it was well suited for the Heemstede track in Holland. I have not tried them since because I have some stock of GRPs and Speedmind. GRPs are great IMHO.
#3597
I can sometimes get through 2 club racedays and practice with a set of 35 Jacos. Most everyone here runs Jaco and most run 35's. Depends a lot on the smoothness of the surface you are running on.
Someone just brought in some GRP's never tried them, maybe I will try them out.
#3598
i also save all raceday/qualifying tires to practice with...
#3599
I tested a set of the old serpent springs this weekend (blue front, yellow rear) and was wondering what spring combination is equivalent to that setup w/ the new serpent springs ?
Thanks in advance
Thanks in advance
#3600
DJ Apolaro
