Old 05-05-2008, 12:56 PM   #3586
Sow&Steady's Avatar
Originally Posted by ammdrew View Post
no pics looks like most ,Will see if we can come up with some, end of race we just wanted to get on the 400 mile drive home.
That is a looooong way to drive to a race!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-05-2008, 09:17 PM   #3587
rcabj's Avatar
Default traction and grip
hi guys...sorry if my questions sound silly,
usually when i go to different tracks for racing i will always get early information regarding the track before i arrive. so that makes thing sort of easier to preset the car.
my question here , how do we determine whether d track is at what traction and grip level if we have no info's.
and what is the base setup u guys start with for
1. low traction
2. high traction
thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-06-2008, 01:17 AM   #3588
Sow&Steady's Avatar
1. low traction
2. high traction
thanks
Try to find out what shores people are using there generally (say for a previous club race). That should give you a general indication of the traction but if its a temporary track made on a car park (and no sugar water is used) then you can expect it to be dirty/dusty and very little traction. I would sit out until some rubber is laid before going out to try my car.
If you have absolutely no reference, go to the track and sit out first while watching others testing their cars. Then check out the performance, ask what shores they're using ... you don't have to be the first one out on the track right?
Old 05-06-2008, 03:23 PM   #3589
gearhead13's Avatar
Why dont the serpent diffs have belt guides on both sides??
My rear belt rides only half on the diff, new belt, tightness set at default, and the cams set the same both sides (double checked).
If I move the rear drive gear over so that the belt rides fully on the diff, then I have had the brake disc come uncoupled from the drive pins. If that doesnt happen, the belt falls off the diff.
Has anyone modded a diff with a guide on the other side?
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 05-06-2008, 04:01 PM   #3590
Never had that problem with my 710 or 720, not unless your bulkheads are worn or bent, then you need to replace your rear bulkheads, that is the reason why your rear belt doesn't center on the diff.
hello is offline   Reply With Quote
Old 05-06-2008, 04:52 PM   #3591
LOW ET's Avatar
Trader Rating: 97 (100%+)
how often do you guys replace tires? every race day, every so many laps, pit stop during the main?
what everyone's thoughts on jaco nitro shoes vs. grp tires? are the shore ratings basically the same?
LOW ET is offline   Reply With Quote
Old 05-06-2008, 05:50 PM   #3592
MMR driver Andrew Tq's and finishes second in the season opener 37th Heart Of America Series with his Mega powered Serpent 720.
Congrats on your performance. Way to go!!
Paolo M is offline   Reply With Quote
Old 05-06-2008, 06:08 PM   #3593
s10dude's Avatar
i qualify on a new set and use fresh set for main....every race...
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-06-2008, 07:51 PM   #3594
rcabj's Avatar
for me it depends on the "budget"
but at big races they always has tyres ready for each heats and finals. and like s10dude mention fresh pairs are better if u have the resources. But for budget racers like me, when i practice with new tyres i will keep them when they reach certain diameters that can be used for heats in future races. i keep them in air tight containers. this way i get to practice and already "trued" tyres
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 05-07-2008, 12:28 AM   #3595
Sow&Steady's Avatar
I never had this problem with the 710 or the 720. There is something not quite right in the assembly somewhere.
Old 05-07-2008, 12:33 AM   #3596
Sow&Steady's Avatar
I'm a cheap-skate ... last weekend I used one set of tyres only for a club race. This was 4 x 5min heats and one 10 mins final so its only for a total of 30 mins racing time plus about another 10 mins total of warm up. I used GRP 37 fronts and 40 rears, started with 61mm and 62.5mm.
I've tried the JACO ones on Serpent rims courtesy of Julius a couple of years ago and it was well suited for the Heemstede track in Holland. I have not tried them since because I have some stock of GRPs and Speedmind. GRPs are great IMHO.
Old 05-07-2008, 12:46 AM   #3597
gearhead13's Avatar
I can sometimes get through 2 club racedays and practice with a set of 35 Jacos. Most everyone here runs Jaco and most run 35's. Depends a lot on the smoothness of the surface you are running on.
Someone just brought in some GRP's never tried them, maybe I will try them out.
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
Old 05-07-2008, 06:57 AM   #3598
s10dude's Avatar
i also save all raceday/qualifying tires to practice with...
Old 05-12-2008, 08:22 AM   #3599
Questions??
I tested a set of the old serpent springs this weekend (blue front, yellow rear) and was wondering what spring combination is equivalent to that setup w/ the new serpent springs ?
Thanks in advance
jlopez92 is offline   Reply With Quote
Old 05-12-2008, 02:21 PM   #3600
dj apolaro's Avatar
Thanks in advance
Try new blue fronts and new orange rears. Should feel similar.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
