Go-Tech Engines Thread
#2312
anyone running the 3 port r in a buggy on an outdoor track? our outdoor season is getting ready to start and i have run about a gallon through mine on our indoor track and it flat out rips!!! running a jp3 pipe and 13 tooth cb i couldnt ask for more but am wondering what to expect on the bigger outdoor tracks this spring/summer here in ohio. maybe go to a 14 tooth cb? i dont want to lose the low end it has now but dont want to wind it out too hard either. any thoughts?
#2314
Maximo
Thanks for your help mate. Guess what it was a Duratrax temp gauge. Well won't be using a temp gun again. Back to the tried and trusted method, Smoke trail, Spit and sizzle, glow plug check, ect ect.
Maximo YGPM
Vigilante212
Yes it was tempted at the plug.
Thanks for all your help folks kindly appreciated.
Maximo YGPM
Vigilante212
#2320
Maximo
Maximo YGPM
Vigilante212
Maximo YGPM
Vigilante212
#2321
I have the Go 7 port and I am using Mugen aluminum shoes with 1.1 springs. This helps to increase the bottom a little bit more.
#2322
Hi guys,
I am a newbie to nitro & I have been running a GO 5 port for the last couple of months. Recently, I installed a turbo head button & was pretty happy with the increased power. However, I have run into a little tuning problem. After running for a while, the engine sputters & there's even a loud 'pop' from the exhaust. What could be the cause of this? I measured the head temperature & it was less than 100 deg C. On top of that, I am getting 'sticky throttle' in that the engine is slow to rev down. I know that without further details, it's not easy to figure out what is (are) the problem(s) based on this simple description. Some educated guess would be appreciated. I have just changed a new fuel tank & new tubing because I was getting the 'sticky throttle' earlier so I hope that potential area of concern is eliminated.
Regards,
Joe Ling
Regards,
Joe Ling
#2323
Hi guys,
Regards,
Joe Ling
Regards,
Joe Ling
#2325
Hi guys,
Regards,
Joe Ling
Regards,
Joe Ling
Adrian
2Likes
