Like Tree1Likes
Sirio engines thread
Old 08-17-2007 | 01:33 PM
  #2101
Corse-R's Avatar
Originally Posted by GMartinez
only seen a pic of it 1 thing that was mentioned a magnesium head is being used I will post some info if I can get any myself
Uhm... if are like the ones being used on the European Championship... I could say that are Aluminium heads, the unique is that are drilled to be lighter, but not Magnesium.
Corse-R is offline
Old 08-17-2007 | 02:45 PM
  #2102
tl2111's Avatar
Originally Posted by Scott Fisher
Compress the spring down 1.3mm past the end of the crankshaft. Very little gap. Maybe .3mm gap.
Hi Scott, dont understand what do you mean?? do you mean the spring lock nut with 1.3mm thread protruded out?
tl2111 is offline
Old 08-17-2007 | 03:33 PM
  #2103
GK
They are magnesium, Jilles was using it... Here is part of an interview he did with redrc:
"Commenting on the new magnesium head from Sirio which he ran in the 2nd and 3rd sessions Groskamp said, ‘It felt actually really really good. I talk later with Sirio and see what we are going to do with the head but it was really good. Tomorrow we are going to try it again."
And a pic:
GK is offline
Old 08-17-2007 | 07:40 PM
  #2104
I think so. Turn the nut that compresses the spring until 1.3mm of thread shows.
Scott Fisher is offline
Old 08-22-2007 | 01:48 AM
  #2105
Default evo3sti
hello and good dae everione. im running a sirio evo3 sti 3 port in my mtx4. i was wondering if anione had clutch settings and gearing to match this engine so that i can get max performance out of this engine. would anione be kind to me and post it here? thanks =)
lance04 is offline
Old 08-22-2007 | 04:08 AM
  #2106
itchy b's Avatar
First,
what size track are you running on and what level of traction/
If you run on a large trrack with med - high traction you could try a 1mm -1.2 mm on the clutch spring and .4mm -.5mm endplay using the Mike Swager clutch building method with either 17/ 23 pinions or if the track is really big 18/ 24 pinions will work.
This engine has loads of power and revs so try a couple of different combos and see what works for you best.
itchy b is offline
Old 08-22-2007 | 04:49 AM
  #2107
Originally Posted by itchy b
First,
thanks itchy b, im running on a small to med, pretty technical track with high traction that causes traction roll haha..... so im guessing 17/23 will work? and i have to drill out the clutch i suppose? do u have a link to Mike Swauger's method? thanks a whole lot =)
lance04 is offline
Old 08-22-2007 | 06:24 AM
  #2108
itchy b's Avatar
You will want to ru a 16 -22 or 17 22 pinion set to get the Sti to sing then
If you are traction rolling then try checking the front track with as if you run under 198mm in width widen it up a mm or 2 as this will help keep it on it's wheels
itchy b is offline
Old 08-22-2007 | 02:38 PM
  #2109
What needle settings is everyone using for the Sirio EVO III Kanai. Non-STi... Thanks fellas
mebejammin is offline
Old 08-25-2007 | 04:18 AM
  #2110
itchy b's Avatar
Default Evo II Worlds-Evo III
Hi All,
Is the piston/rod/liner set for the Evo II worlds still available as i have one in need of a rebuild.
Is the Evo III piston/liner/rod set compatible with the Worlds Evo II?
if yes on anything can you please post a link to the site.
Cheers
itchy b is offline
Old 08-25-2007 | 07:33 AM
  #2111
Not sure of the piston and sleeve questions but here is the website. Not much help here. I was PM'ing another user here for a manual. If I get it I will post it here.
http://www.micromotori.com/
Old 08-27-2007 | 01:29 PM
  #2112
Rc_Boy89's Avatar
Hi guys just picked myself a S12T3ISTI am curious to know what a good pipe is to go with this engine? at club meets I race on a reasonably small track but each month take a trip to a larger track with 66m backstraight so any suggestions appreciated.
Cheers.
Rc_Boy89 is offline
Old 08-27-2007 | 01:49 PM
  #2113
Corse-R's Avatar
Sirio 2611... Don't settle for other things... no matter what they tell you. No one better than Sirio to release a pipe who suits the best for your Sirio engine.
With the proper gearing and clutch, you could be really well on such different tracks. 66meters of backstraight is not much at all, enough to clear the crankcase from excess of fuel.
Corse-R is offline
Old 08-27-2007 | 01:57 PM
  #2114
rmdhawaii's Avatar
Interesting. I will be testing this very soon. At present, I am using a Skyline VR12 Plus pipe with the .12 STI and I'm not very happy with the bottom end performance. I'll see if it's any better with the 2611.
rmdhawaii is offline
Old 08-27-2007 | 03:17 PM
  #2115
Corse-R's Avatar
Usual.... nothing that someone wanting to do some pipes to ruin an engine. Sorry for the rant, but I'm fed of those VR12, JP-1/2/3 and others.... Nothing than Sirio to make a pipe for their engine, the same applies to Novarossi for their mills and similars (Think on Max/RB/JP/...).
[Mode Rant Off]
Corse-R is offline
