Ninja Engine by GRP
Old 05-08-2007 | 12:54 AM
  #781
RC=Realy_Costly's Avatar
hey guys, am proud to say that just days ago i bought my first pro end motor and went with the mr.12 t01, to bolt in my mtx4-r
engine looks great and i cant wait to fire it up. But im not sure as to how to run it in, any one got suggestions? and also does conrod need to be changed after break in?
cheers
RC=Realy_Costly is offline
Old 05-08-2007 | 01:15 AM
  #782
Dynamite's Avatar
if you look back a few pages costly, mike swauger posted how he runs his ninjas in this might help you
Dynamite is offline
Old 05-08-2007 | 01:31 AM
  #783
rmdhawaii's Avatar
cheers
The "Engine FAQ" section of the .12 Engine KB has a summary of Mike S' break-in notes for the MR12-T01
rmdhawaii is offline
Old 05-08-2007 | 01:37 AM
  #784
Dynamite's Avatar
this is the page http://www.rctech.net/forum/showthre...&page=14&pp=40was more then a few back.... or just check nitrokb
Dynamite is offline
Old 05-08-2007 | 03:33 PM
  #785
rmdhawaii's Avatar
I went to the Ninja Engine Web site and found absolutely zero info on the tuned versions. Anybody know where I can find some details? And could someone clue me in on the significance of magnesium?
Also, on the MR12-T01A, the Ninja Web site reads:
It is designed in order to offer the maximum possible torque and RPM on a 3 port engine, in accordance with the EFRA Rules.
Is this a good thing or a bad thing when going up against IFMAR/ROAR legal engines?
Old 05-08-2007 | 07:36 PM
  #786
gentleman81's Avatar
Default i don't own a bench
Originally Posted by Mike_Swauger
1st Tank at idle. Shut it off and let it cool down. Make sure the piston is at the bottom.
2nd tank idle
3rd tank 1/4 throttle
4th tank 1/4 throttle
5th tank 1/2 throttle
6th tank 1/2 throttle
7th tank 1/2 throttle
8th tank full throttle (make sure engine is running rich)
9th tank 1/2 throttle
10th tank 1/4 throttle
Put the engine in the car and run two or three tanks at a rich setting on the track and then it will be o.k to lean it out.
i don't own a bench break in setup. what is the proceedure, for breaking in the motor in the car? just use the cd?
gentleman81 is offline
Old 05-09-2007 | 12:36 AM
  #787
M7H's Avatar
M7H
Last year it wasn't, but this year EFRA changed there rules regarding engine specifications, they are now the same as IFMAR....
M7H is offline
Old 05-09-2007 | 12:53 AM
  #788
thanks for all your help guys
cheers remo
Old 05-09-2007 | 03:26 AM
  #789
etgdpu's Avatar
Default Ninja MR 12 T01A conrod
Hello,
I would like to share my finding on the conrod of the engine and have your feedback. When I opened the engine just after the break in to clean it, I noticed a play between the conrod and the piston pin. I assumed that I shouldn't change it since it had only about 1 liter of fuel.
Then during the first race, the engine performed very well. Thanks to my mechanic the engine was working to 105C and it could stay on idle for more than 5 minutes and after that to respond perfectly to full throtle without flaming out.
The performance was equal to all other mod engines in the track or I did not feel the need for more power.
After the race when I opened it again I noticed the same play in the conrod and the pin.
There is no bushing there. I slightly heated it up with the heat gun and when it reached approx 70C the play started dissapearing.
What is your experiences/opinions on that.
Since the engine performed perfectly on the track and the temperature was about 105C, I would like also your opinion for the following:
I used 1 teeth smaller both pinion gears and 1 teeth larger both spurs from the default. I suppose that this is the shortest available gearing for the MTX4. While the other team mateswith the MTX4s using other engines, i.e. JP FX03M used the default pinions and only 1 teeth larger both spurs.
My centax spring was also much tighter than the rest. I was about 1.6 and the other about 1.0. However, the whole package worked perfectly and no signs of wear in the shoe or anywhere else. Any comment?
Thanks in advance
etgdpu is offline
Old 05-09-2007 | 06:57 AM
  #790
Wolverini's Avatar
Good morning gentlemen (ladies if you frequent here as well).
I have just found this thread this morning related to my recently purchased Ninja MR21B01A engine. I am also the owner of a X1-CRT truggy and would like to know if there is a seperate thread related to this new engine or if someone would be so kind as to link me to it. I have read the ninja-engine site but I wanted something a little less *clouded* by marketing hype. Any/all help is greatly appreciated.
Wolverini is offline
Old 05-09-2007 | 07:52 PM
  #791
moy's Avatar
moy
since the new mario rossi tuned came out is the old version still gonna be available? the new mario rossi tuned really expense though.. $649 for the RO1..
moy is offline
Old 05-10-2007 | 04:53 AM
  #792
sohlman's Avatar
The R01A is still available and will continue to be.
sohlman is offline
Old 05-12-2007 | 08:40 AM
  #793
Pooh2's Avatar
We have them cheaper than that at www.rcthunderhobbies.net 347.202.7247 call and ask 4 Dean or Danny.
Pooh2 is offline
Old 05-12-2007 | 08:57 AM
  #794
Pooh2's Avatar
We have .12's and 21's in stock.
Pooh2 is offline
Old 05-12-2007 | 09:10 AM
  #795
Wolverini's Avatar
I just spoke with Daniel at the shop and he says he can have his distributor get him the .28s as needed. EXCELLENT news indeed. I look forward to meeting you at the Tri-State tomorrow Dean as I'm the site administrator for the track we're racing at.
