Ninja Engine by GRP
#751
I think the temp readings are a combination of differing factors, but I think the main factor is the head design.
My Ninja MR21- R01A will not run very good until it hits at least 260F+. At 240F it is so fat it would hardly even shift into second gear. 275F- 280F seems to be the sweet spot for me.... performance, safety and fuel mileage wise.
If you have an Exergen DX-501 be careful..... the sensor window will contact the glow plug and damage the temp gun. Put an exhaust gasket arond the nose cone of your temp gun and you'll prevent it from going to deep into the head.
#754
Originally Posted by Mike_Swauger
1st Tank at idle. Shut it off and let it cool down. Make sure the piston is at the bottom.
2nd tank idle
3rd tank 1/4 throttle
4th tank 1/4 throttle
5th tank 1/2 throttle
6th tank 1/2 throttle
7th tank 1/2 throttle
8th tank full throttle (make sure engine is running rich)
9th tank 1/2 throttle
10th tank 1/4 throttle
Put the engine in the car and run two or three tanks at a rich setting on the track and then it will be o.k to lean it out.
2nd tank idle
I know it's been a while since you posted this info..
, but would you recommend this brek-in procedure for the .21 Ninja..??Thanks in advance bro..
#755
The head is shorter than most other 12's. Plus the opening by the glow plug is wider so you are reading differently than most other motors. I couldn't get my car to shift (still breaking it in) until I got the temp up to 210. I thought that might be a little hot. But, it isn't really. It's kinda like reading about 180 on other motors. Even though people are saying that the motor runs good at 270, it's probably more like 240-250. Just reads higher on this motor. Will take a little while for me to get used to it. Just my 2 cents.
#757
There is currently NO better engine for the money...... or even $100 more.... until the Mario Rossi mod come out
#759
Who ever requires a good price on a brand new BOSS .12 Engine + conical manifold and pipe let me know. Offer starts at $200. You can either PM me or email me on [email protected]
#764
Originally Posted by THE DOCTOR
Anyone?
The 02 rods (come with R01A) last even longer.
#765
Originally Posted by sohlman
I've worn out a piston and sleeve and kept the rod for the replacement p/s. It all depends on the play in the bushing...any play, replace it. It should be snug.
