Like Tree2991Likes
1/12 forum
Old 03-10-2007 | 03:49 PM
  #24121
PoLsKiE's Avatar
ya i want to do 12th scale but no track for it
PoLsKiE is offline
Old 03-10-2007 | 10:26 PM
  #24122
wallyedmonds's Avatar
Originally Posted by peded
I see many of you guys are running the rear most hole to mount the center shock on the anntenne mount. What advantages does it have?
Also When i tried to fiddle with that I couldn't do it. When everything was done a good then i saw that my shock was fully compressed and i couldn't put any preload on the spring. Whats wrong? Is the shock too long or too short?
read this,he has a good way of telling how it works.
http://markpayneblog.blogspot.com/20...erentials.html
wallyedmonds is offline
Old 03-10-2007 | 10:35 PM
  #24123
Iceracer's Avatar
I'm in the market for a used 1/12th scale for carpet. What should I be looking for? Local club stocks AE parts, and corally. Is a 12L4 all I'll ever need at a club level? Minimum specs for a servo? I see a lot of used ones with hitec Hs225mg servos. Are they ok?
Iceracer is offline
Old 03-10-2007 | 10:39 PM
  #24124
if your local club stocks only AE and corally (they should get CRC)
then get a L4 with a JR 3550 servo.JR makes them again and there cheap and work good. but the L4 is made for a fut servo,but it will work,i did it for years,
Old 03-11-2007 | 05:11 AM
  #24125
protc3's Avatar
there is more to it than that.that just explains pod droop.shock length is another adjustment that controls the leverage point.you can adjust your shock length longer to smoothe the car out and still achieve your 0-1mm of pod droop and completely change the feel and reaction of the car.this is also true with shock angle.these are all really usefull adjustments.pod droop only controls so much.
protc3 is offline
Old 03-11-2007 | 05:20 AM
  #24126
protc3's Avatar
the 12L4 is a great car.there is a ton of support for the car everywhere and it is a proven design.there are a bunch of upgrade chassis kits from a bunch of different companies for it if you ever want to upgrade also.you can not go wrong with it.
protc3 is offline
Old 03-11-2007 | 10:51 AM
  #24127
Does anyone know who makes a hollow rollover antenna? I don't think Slapmaster makes one anymore.
thanks
chuck
mackin is offline
Old 03-11-2007 | 11:13 AM
  #24128
Thraex's Avatar
speedmerchant does.
Thraex is offline
Old 03-11-2007 | 11:17 AM
  #24129
Thanks,
I'll check it out.
chuck
mackin is offline
Old 03-11-2007 | 05:32 PM
  #24130
how do you do droop other than shock length on your car.
Old 03-11-2007 | 05:58 PM
  #24131
intimidator's Avatar
will a novak brushless motor fit a 12l4 pod ok?are there other brushless motors besides nokak that work with the gtb?
intimidator is offline
Old 03-11-2007 | 06:04 PM
  #24132
Marcos.J's Avatar
Super Moderator
lrp
Marcos.J is offline
Old 03-11-2007 | 06:20 PM
  #24133
will a novak fit?
Old 03-11-2007 | 06:21 PM
  #24134
Marcos.J's Avatar
Super Moderator
will a novak fit?
yes
Marcos.J is offline
Old 03-11-2007 | 06:37 PM
  #24135
lbckevin's Avatar
I run the Novak 4 cell GTB and the 4300 and it fits great...Need to move electronics around a little to balance it out.
lbckevin is offline
