JP engines
#602
Originally Posted by Slo-MTX4
OK Boy and girls, i am just about ready to throw my JP in the bin. I have rebuilt the carby, tried a different carby and i still cant get a tune on this engine. It a JP FX3 Full option, it wont idle properly, i cant get it to rev or pull out of a corner and last night, it went from running at 70 degrees C in warm up to 233 deg C at the end of a 6 minute race has anyone got any ideas?
Cheers Daniel
Cheers Daniel
. I've talked to other JP users and some of them claimed they had the same issues
. I don't know what to do next which makes this quite frustrating. I have to resort to my 3 year old reliable MR12 TQ racing motor to complete races.
#605
Same problem also happened to me. Piston was all black with carbon. Funny thing was temp was still good at about 210. It was good for 3 to 4 laps from start and then it would lose its power from thereon. Seems like it did not overheat but just did not have enough gas passing through.
Could someone assist
Regards
Regards
#606
Anyone have the problem with blowing the seal out of the front bearing. My motor has right around a gallon through it and it has blown this seal. What is a better bearing to put in so this doesn't happen again?
#607
#608
#609
Originally Posted by B4
Same happened to me. I haven't replaced my bearing yet, keen to hear what is a better replacement than the standard one though.
They are sure to be better than what the engine companies are using.
#611
Hi guys,
I haven't ran my .12 JP (forgot the model, black crankcase, purple heatsink, SX12 or something on the side) for about 3 years. However, I put after-run oil in it and made sure nothing got into the engine during this time.
Any tips before firing it up after 3 years of no activity?
#613
Hi Guys,
I need to replace the piston/sleeve and rod in an FX 21 R03 engine and don't want to buy the JP parts as the engine is well worn. Can someone tell me what Novarossi p/s/r can be used as a substitute?
#614
Originally Posted by ralph m
Hi Guys,
Our Bi metal piston and sleeve set will fit.
#615
Hi Guys,
1Likes
