Converting a BK2 to a XXX-CR
#19
I already have the bk1 tranny and I have trinity alum. rear hubs. So would that save most of the exspense. I have a regular chassis not the graphite. I was thinking if I broke the chassis I would replace it with the cr chassis. So if I just change the steering and towers and the new ball studs and tie rod ends. Would I benifit from this. I'm trying not to get a new kit. I want to get a m11 so I would rather get that then a new car.
#20
I can appreciate a budget......so get the new rear arms, cr pivot, hubs, rear shock tower, the new steering rack, and you will be good to go
do you need part numbers?
#22
you will need the following
rear arms losa2132
rear tower losa2100
rear pivot block losa2113
rear hubs losa2129
steering rack and bellcranks losa 1621
top hat spacers for rack losa 1233
you will also need some buttonhead screws, 2 gold washers, 2 mini locknuts
losa6256, 6350, 6306
make sure to use the xxx dogbone(or cvd)with the xxx axle as well.
front tower losa 1104
rear arms losa2132
rear tower losa2100
rear hubs losa2129
#24
i agree....what i would do...is change the steering system...and convert to the old tranny and the necessary stuff to do the conversion...and leave the rest as the original. that way..you get some sort of a "bk3" or "bk2.5"
WOOO POST NUMBER 500! LETS CELEBRATE!!
NANANANANANA
"my spidey sense is tingling"
NANANANANANA
#25
TLRacing
Originally Posted by killer89
Unless you plan on changing the camber link location in the rear to something unusual, keep the old shock tower and dont go with the new one.
I noticed on one factory losi driver's car, he is still using the old tower for graphite strength.
I am running the 4th hole, the new one not on the old tower at SoCal.... so does truhe's setup....
#28
If you run the new cr body you are going to want to run the new tower if only for the lower wing position. The old tower's lowest wing mount holes are too high for how low the new body. Just my opinion
