Old 07-25-2006, 12:24 PM   #16
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
Originally Posted by RC Guru
you mean the back battery area where theres a little block sort of thing?
frank is saying cut about 1 inch foward from the very rear of the side battery supports. Right where my CR chassis is fracturing.
killer89 is offline   Reply With Quote
Old 07-25-2006, 12:25 PM   #17
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
The back battery area, like where the battery strap is captured in the rear. About 1in. forward from there.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-25-2006, 02:14 PM   #18
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
oh i see..okay thanks
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 07-25-2006, 04:38 PM   #19
pvtysux's Avatar
I already have the bk1 tranny and I have trinity alum. rear hubs. So would that save most of the exspense. I have a regular chassis not the graphite. I was thinking if I broke the chassis I would replace it with the cr chassis. So if I just change the steering and towers and the new ball studs and tie rod ends. Would I benifit from this. I'm trying not to get a new kit. I want to get a m11 so I would rather get that then a new car.
pvtysux is offline   Reply With Quote
Old 07-25-2006, 06:32 PM   #20
CaseyP's Avatar
I can appreciate a budget......so get the new rear arms, cr pivot, hubs, rear shock tower, the new steering rack, and you will be good to go
do you need part numbers?
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 07-25-2006, 06:45 PM   #21
pvtysux's Avatar
if you got them that would be great
Old 07-25-2006, 06:46 PM   #22
CaseyP's Avatar
you will need the following
rear arms losa2132
rear tower losa2100
rear pivot block losa2113
rear hubs losa2129
steering rack and bellcranks losa 1621
top hat spacers for rack losa 1233
you will also need some buttonhead screws, 2 gold washers, 2 mini locknuts
losa6256, 6350, 6306
make sure to use the xxx dogbone(or cvd)with the xxx axle as well.
front tower losa 1104
Old 07-26-2006, 09:34 AM   #23
killer89's Avatar
Unless you plan on changing the camber link location in the rear to something unusual, keep the old shock tower and dont go with the new one.
I noticed on one factory losi driver's car, he is still using the old tower for graphite strength.
Old 07-26-2006, 10:07 AM   #24
i agree....what i would do...is change the steering system...and convert to the old tranny and the necessary stuff to do the conversion...and leave the rest as the original. that way..you get some sort of a "bk3" or "bk2.5"
WOOO POST NUMBER 500! LETS CELEBRATE!!
NANANANANANA
"my spidey sense is tingling"
-valentin
www.csjunkies.com
Old 07-26-2006, 10:17 AM   #25
TLRacing
Frank Root's Avatar
I am running the 4th hole, the new one not on the old tower at SoCal.... so does truhe's setup....
Old 07-26-2006, 10:27 AM   #26
killer89's Avatar
Ah okay...
Good luck this weekend Frank. Sounds like an awesome track from what I hear. Just wish I could go...
Old 07-26-2006, 11:18 AM   #27
TLRacing
Frank Root's Avatar
Why can't you make it??
Old 07-26-2006, 11:46 AM   #28
CaseyP's Avatar
If you run the new cr body you are going to want to run the new tower if only for the lower wing position. The old tower's lowest wing mount holes are too high for how low the new body. Just my opinion
Old 07-26-2006, 11:56 AM   #29
TLRacing
Frank Root's Avatar
I second this notion...
Old 07-26-2006, 06:55 PM   #30
killer89's Avatar
My parents don't want me to go. I'm not even sure if they are going to let me finish the series.
Converting a MF2 convikt Electric Off-Road 2 12-08-2007 01:43 PM
Converting to Pro Kit Chevron89 Nitro Off-Road 9 07-12-2007 10:36 PM
Converting 4WD To 2WD Toolbox™ Electric On-Road 7 01-28-2007 07:29 AM
Converting an XR 80 to the XR8 llamont Nitro On-Road 16 09-06-2006 07:05 PM
converting TC3 to TC4 AEDave Electric On-Road 2 11-10-2005 01:50 AM
