Mugen MTX-4
#4085
Originally Posted by blount
what about rear uprights and front lower and upper arms?
b
b
#4086
Originally Posted by GrandeGixxer
100,000 in the fron diff? Wowzers!! When I run a diff, usually 30,000 in the front and 10,000 in the rear.
#4087
Originally Posted by stefan
That's what I always ran in my MTX3, 50K in the rear and either 1-way or 100K diff up front. Works great.
I'm thinking to use front gear diff after the one way bearing is out of service.
Some said ( unproven ) using one way is faster cornering speed than using front gear diff ?
#4088
Originally Posted by HarKonnenD
Anyone selling an MTX4 roller or something for a good price? I have an rc10gt with spares servos, setup for re and se engines, and will also throw in some $$ for difference. Anyone?
#4090
Trying to get my car setup, I have a couple of questions.
1. What type of charger are you guys using to charge the receiver batteries and the batteries for the starter box.
2. What percentage fuel do should I use to break in my OS.
3. If I use 30 percent do I need to shim the head.
Thx.
Thx.
#4091
Thx.
Thx.
I use it for all the packs: Tx, Rx and starterbox... yes, another kept of my earlier electric days, two 7.2v racing packs to get 14.4v for the starter box, nothing defeats my starter box and remain unstarted..
Use the same fuel, if you plan to race with 30% break-in with 30%, accept nothing than the best fuel available, check your LHS and get one from a reputable brand.
Of course, the majority of engines came shimmed from factory for being used with 15-20% nitro maximum (unless the instructions tell you the opposite). Check on the OS thread for more information about this.
#4092
i assume you are running a OS TZ, if that's the case the engine is shimmed for 30% out of the box, you will not need to add shim.
Thx.
Thx.
#4094
PROSPEC
Does anyone know when the MTX-4 Prospec or MTX-4R is going to be out ????
#4095
you are way ahead of yourself , considering Mtx-4 just came out few month ago i dont see mtx-4 prospect coming out anytime soon. mugen usually introduces their propect model at the end of the product cycle so, i guess maybe another 2 years or so ?
