Like Tree3Likes
Tamiya TRF415
Old 03-30-2006 | 12:38 AM
  #13621
Kai747 - who makes those towers and top deck?
Besercoe is offline
Old 03-30-2006 | 01:10 AM
  #13622
Square or Kai?
Rick Draper is offline
Old 03-30-2006 | 03:10 AM
  #13623
TRF415boy's Avatar
Originally Posted by Sryder7
I'm having some trouble with my oneway. I currently have a Yok diff in my original 415 and want to put my one way in, but when i do 1 side's suspension movement binds. The side that binds has a different lenght outdrive. When you stand the 2 next to each other it's 4 or 5mm taller and at least half of that sticks out when it's mounted in the car. Is this orginal or are both outdrives suspposed to be the same lenght? I Bought the car used so i don't know. IF this is orginal, i think my CVD shafts maybe different. they aren't blue, and are labelled "46" i'm guess that that means they are 46mm long. Is this the orginal lenght or are the orginals shorter? Thanks for any help you can provide.
Right, you have one outdrive for the standard 415 which is longer and one for the MS/MSX which is shorter (and the same as for the TA04/TRF414 series). get yourself the following item :
53613 TA04 LIGHTWEIGHT CUP JOINT FOR RACING FRONT ONE-WAY
and you'll be sorted.
TRF415boy is offline
Old 03-30-2006 | 08:18 AM
  #13624
Carl Giordano's Avatar
Can't seem to find the part number for the White spring set color coded at the top for the 415...please help, placing an order today with Tamiya
Carl Giordano is offline
Old 03-30-2006 | 08:25 AM
  #13625
Fred Hubbard's Avatar
Tamiya USA doesn't have them anymore, in fact that are supposedly discountinued. You will need to order them from overseas. Here is the part number: 49382
Fred Hubbard is offline
Old 03-30-2006 | 08:29 AM
  #13626
Thanks...never fails
Old 03-30-2006 | 09:07 AM
  #13627
Not sure if they will ever get more since it's discontinued but here's the Tower link...
http://www2.towerhobbies.com/cgi-bin...L=++&search=Go
I have two sets.
Nexus is offline
Old 03-30-2006 | 09:10 AM
  #13628
I have two sets.
No they won't, gotta get 'em from overseas. They are available in Hong Kong and Singapore.
Old 03-30-2006 | 01:24 PM
  #13629
Guo Chean's Avatar
is from shooter.
Guo Chean is offline
Old 03-30-2006 | 01:59 PM
  #13630
Burlap's Avatar
49xxx numbers usually mean limited build number, so if it is out of stock at most places, it is going to be hard to get.
I love the TRF body clips that came out last year, and disappointed they are not being made any more since they were a limited build part. Please Tamiya, do another run on them, I want to put a set on my F103GT
Burlap is offline
Old 03-30-2006 | 02:03 PM
  #13631
Burlap's Avatar
Post
Originally Posted by Guo Chean
is from shooter.
Can you give us some more info, like part numbers or who stocks them? I tried to do a Google search with the info there, and keep getting gun websites.
Burlap is offline
Old 03-30-2006 | 04:51 PM
  #13632
Hi everyone, Im new to the 415 and racing is starting soon but my local hobby shop doesnt carry the parts for this car in stock and I'm gonna need some spares. Ive heard the rumors that this car is very strong but Im asking to the long time 415 racers what are the parts that are most likely to break on this car if done so? Thank You.
Kingsbury is offline
Old 03-30-2006 | 05:23 PM
  #13633
veecee's Avatar
here it is - http://www.precisionrc.com/nv/car/pr..._name=shooters
I'm sure most shops from HK would have them as well.
veecee is offline
Old 03-30-2006 | 05:49 PM
  #13634
snopro31's Avatar
Does anyone have problems with the front body mounts breaking? the bumper it always fine just alot of times i come off with one broken front body mount. is there a fix for it ?
I ask as i see that front upper bumper on this link
http://www.precisionrc.com/nv/car/p...t_name=shooters
Maybe this will help with the body mounts breaking? they always break off right at the body pin holding down the foam.
snopro31 is offline
Old 03-31-2006 | 05:13 AM
  #13635
CRASH's Avatar
Default Front Diff for 415MS
What parts due I need to make a front diff for this car? Does Tamiya make one for it or do I have to use Yokomo parts?
Also what parts due I need to make the center oneway fixed?
I am getting a 415MS and going to be running it mainly on carpet.
Thanks,
CRASH is offline
