Porting & Polishing question's >
Old 01-29-2006 | 09:11 PM
  #16
EdwardN's Avatar
Originally Posted by onnetz
after looking at the last image show the min and max angles, how would you go about measureing those?
It will be tough to do it by hand, on the CNC it comes right from the drawing. Only can sugest mesure it by eye.
Here some more pics for modding.
Attached Thumbnails Porting & Polishing question's-shaft12.jpg   Porting & Polishing question's-shaft12-1.jpg   Porting & Polishing question's-shaft12_2.jpg   Porting & Polishing question's-shaft12_5.jpg   Porting & Polishing question's-shaft12_6.jpg
EdwardN is offline
Old 02-01-2006 | 03:51 PM
  #17
onnetz's Avatar
thats what I suspected.....
care to share some info on modding the crank to advance timing?
I've found bits and pieces on it but it would be nice to have it from a single reliable source.. thanks..
onnetz is offline
Old 02-01-2006 | 10:03 PM
  #18
EdwardN's Avatar
Sure.
Open @35 ABDC and close @ 60 ATDC. It is pretty diccent set up for no-headacke tunning (cluth and gearing). Advanced is open @ 32 ABDC and close @64 ATDC, tehn you will need alter exhust and transfer timings 162-exhaust and 122 ransfer-this set up will give you more RPMs and power, but more difficult to tune the gearing and clutch.
Edward
EdwardN is offline
Old 02-01-2006 | 10:37 PM
  #19
onnetz's Avatar
Sure.
Edward
great info.... thanks..
can you alter the exhaust timeing without messing with the crank? or will that have a bad or no effect..
more power and more tempermental.... I guess you can't have it all..
onnetz is offline
Old 02-01-2006 | 11:56 PM
  #20
ProudSavageOwnr's Avatar
i have ported acouple of engines and u mostly just do wat the pics of the sleeve show u but do not do the crankshaft !!!!!!! u can stuff up the engine i had modified the piston,sleeve and crank and it was runnning sweet but wen i modified the crank it stuffed everything up and i couldnt get a proper tune as for the bits just use the cutting bits i used the round ball cutting bit and it worked good just make sure u dont go any faster than 12,000 rpm on the dremel because u will make ur bit go blunt speeding it up anymore aint gona let u finish any quicker well it might but then u gotta chip in another 50 bucks for bits (or u can just rip them out of the packet LOL)
ProudSavageOwnr is offline
Old 02-02-2006 | 02:50 AM
  #21
texasRanger's Avatar
Default Dremel contacts
ntro75,
Try www.dremel.com or in the USA try 1-800-437-3635,
surely you will find the part numbers your after.
Hope that helps?
Texasranger
texasRanger is offline
