Team Associated TC4
#7126
Losi parts
Anybody want to try the Losi 4 degree C Hubs, Losi Sterring knuckles, Losi Rear Hub Carrier on there Factory Team TC4.
I Also have a P-Dub Bumper 4 Sale.....
Send me a PM
Selling parts real cheap.....
Thanks,
E
Send me a PM
Thanks,
E
#7127
Originally Posted by runnin rc10
This is a FT setup right? If so, do you guys feel the stiffer chassis allows for stiffer setups? Im running a really soft setup comapred to what im used to in TC. I still have the all graphite tub, FT in a few weeks. If there are differences, what should I do different to the FT setups when I put them on my car.
Just transfer your tub setup onto the FTTC4 and I am sure you will be happy with it, then work from there.Thats all I did with mine and it now holds the track record in it's class. The cars are not to dissimilar the FT is alot more constant lap after lap.
#7128
bjspinner
I found the 3 racing shock tower mounts bind the bearings as well. You need to grind short some screws to stop them binding up the bearings.
I am not sure if the 5 mount holes are any better than factory or not.
They seem to be in the wrong place, the mounts are in between the AE options and the front holes are quite a bit more upright than the rear shocks if you try to run the same hole all round.
I think I prefer the AE options for shock mounts, just feels the same on all four corners of the car.
However, the 3 racing camber link mounts I think are much better than the AE ones, because they are one piece.
You don't need four mounting options for the ball stud, never seen any body use the outer two anyway!
#7129
Hey guys finally got to work on my setup a little this weekend. Car was awesome, driver sucked LOL. Here's where I am at.
Front
70 wt losi oil
2 piston
purple springs
inside on arm
3rd hole out on tower
camber - 2nd hole out silver ball stud 2 washers
4 deg castor
4mm ride height
droop - 2mm over ride height
steering rack - silver ball studs no washers
2 shims in front of arms
no shims under blocks
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
camber all the way in black ball stud no washers
inside on hub (switched back to AE hubs)
no washers under blocks
4 mm ride height
droop - 2 mm over ride height
double pink
no sway bar (this made a huge difference)
Team Express Monster geared 37-96
Team Express GP3700's
Protoform stratus 3.0 carpet (Parma Alfa is the way to go though)
Next week I plan on trying to raise the rear roll center by .025 to get some more rotation.
Front
70 wt losi oil
2 piston
purple springs
inside on arm
4 deg castor
4mm ride height
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
4 mm ride height
double pink
#7130
Yes its a setup for the FT. The tub car will need softer setups. Chassis twist/flex will play a big role in the handling... or lack thereof... for that car. Stiffer setups in general work best on a stiffer chassis. You have to take into account roll center too... alot of people look at shock position and spring choice and instantly see "stiff", and dont take into effect the camber link positions/hingepin block shims.
- DaveW
#7131
Thanks for the insight guys. I hope to get teh FT conversion in a few weeks. For now Im going to grab a old tub setup from ae's site and start from there. Its the steve rossi setup. I chose it because is a tight track like man and he used jack the gripper instead of paragon which is the new rule here. I think its a great start. I'll keep you guys posted.
#7135
Originally Posted by biker
Hey guys,
Any info regarding availability dates for the FTTC4 conversion kit..and the best place to pick one up?
http://www2.towerhobbies.com/cgi-bin...&I=LXLPG4&P=ML
Tower says late November.
#7136
sorry guys...got a great deal on a JRX-S today...I drove one last week, smooth as silk. So my tc4 is up for sale, if anyone is interested check the for sale forum.
#7137
They have been out for 3 or 4 weeks now. The local shop has had them also. Thats not saying they might be sold out at this time.
Check around, you should be able to find one.
Hey guys,
#7138
Hey Walter, Have you ever tried running the outter hole on the steering knuckle? I want to angle the steering turnbuckles forward but I can't add any shims to my steering rack. The BMI chassis has the Servo moved forward so I can't do anything more than just a silver ball stud with no washers.
#7139
If you wanna rub fenders with any of these guys check out the Express website for our NORTH SOUTH SHOOTOUT!!!!!
www.tmxpress.net
Express sign up list to date:
Touring stock:
Mark Painter
Mike Kling
Paul Buohl
Ron Binkley
Steve Walter
Sean Walter
Robbie Dodge
John North
Laurie Willis
Tyler Keel
Jason Schreffler
Mike Herald jr
Will Duncan
Billy Duncan
Larry Fairtrace
Guy Hood
Jon Williams
Jeff Cuffs
John Tag
Fast Freddy
Dan Hartman
Arron Sanford
Reggie Wade
George Rylas
Anthony Saunders
19T:
Ray Darroch
Robbie Dodge
Jason Schreffler
Larry Fairtrace
Dan Hartman
Keith Trapp
Craig Xavier
Billy Spence
Ike Peacock
Brandon Melton
Jeff Cuffs
Brandon Hess*
Mike Herald jr*
Touring mod:
Ray Darroch
Keith trapp
Reggie Wade
Justin Listard
Brandon Melton
Brandon Hess*
Jimmy Mac*
Minis:
Mike Kling
Andrew Tag
Ron Zelenka
1/12 stock
Steve Walter
Paul Buohl
Mike Herald sr
Mike Herald jr
Ron Zelenka
Fast Freddy*
Chris Cowder*
Mike Cummings*
Herb O'Loughlin*
www.tmxpress.net
Touring stock:
Mark Painter
Mike Kling
Paul Buohl
Ron Binkley
Steve Walter
Sean Walter
Robbie Dodge
John North
Laurie Willis
Tyler Keel
Jason Schreffler
Mike Herald jr
Will Duncan
Billy Duncan
Larry Fairtrace
Guy Hood
Jon Williams
Jeff Cuffs
John Tag
Fast Freddy
Dan Hartman
Arron Sanford
Reggie Wade
George Rylas
Anthony Saunders
19T:
Ray Darroch
Robbie Dodge
Jason Schreffler
Larry Fairtrace
Dan Hartman
Keith Trapp
Craig Xavier
Billy Spence
Ike Peacock
Brandon Melton
Jeff Cuffs
Brandon Hess*
Mike Herald jr*
Touring mod:
Ray Darroch
Keith trapp
Reggie Wade
Justin Listard
Brandon Melton
Brandon Hess*
Jimmy Mac*
Minis:
Mike Kling
Andrew Tag
Ron Zelenka
1/12 stock
Steve Walter
Paul Buohl
Mike Herald sr
Mike Herald jr
Ron Zelenka
Fast Freddy*
Chris Cowder*
Mike Cummings*
Herb O'Loughlin*
