Tamiya TB-Evolution IV
#3136
To smooth the tape slots and other narrow areas or the whole car you can use strips of sandpaper. Clamp the carbon piece to a bench and sand the edges holding the ends of the strip of sand paper using tension to press against the edge you are smoothing.
Remember that the dust from the sanding is nasty - try not to breath it etc.
I used wet water proof sandpaper on the last chassis I sanded and that seemed to keep the dust down, but was a bit messy and left dust on the chassis.
Too much ca can cause fogging around the glue, it can be cleaned off though.
It looks better if you take your time and don't ca it to the table or your hand...
#3137
I sanded all mine with 400 and 800 grade wet and dry, and the dust got EVERYWHERE, but i got a nice finish
As for sealing it, i used thin super glue and Q-Tips, just put drops onto the Q-tip until it looked saturated, 2-3 drops was ok for me, and then ran it around the edge of the chassis, could do most of a side until it had dried too much, so just chuck that Q-tip and use another.
#3139
Here is a link to the Calandra chassis prep "how to" I was talking about. click here. It shows a 12th scale in the pics, but the method is the same for any c/f chassis.
#3142
Originally Posted by hierog
is there a part number for just the plastic drive cups used for the Tamiya Spool? I broke one of the cups a few weeks back and would like to get some spares
thanks
vic
thanks
vic
#3144
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
The MS version is really nice. Almost has me thinking of another touring car. Still seems like everyone is going to belts again and even the Tamiya team is running the belt car. The EVO IV is a sweet ride.
#3145
#3146
Friend of mine just told me about this awesome thread!
I've got a an Evo 4 MS and I'm just wondering if anyone can help me with the following:
1. I'm running the Tamiya spool kit and I'm just wondering if there is an after market spool that I can get with metal outdrives. I broke two already during one race meet. Both were on the right side. Alternatively, are metal outdrives for the Tamiya spool available?
2. Are front aluminuim hubs available for this car? I know that Square makes aluminium hub carriers but I'm not sure if they make aluminium hubs for the front.
#3150
yes, square makes front knuckles as well, speetech also.
2Likes
