Schumacher cougar LD3
#586
Looking at the Manual I assumed the wide and narrow pivot options on the rear hub tied in with the two pivot options on the wishbone - i.e if you are using the wide pivot on the wishbone then the rear hub insert is set with the hole on the outside
How I have looked at a couple of cars running at our track and also how my car was set up when it arrived, the hub insert is with the hole on the inside but still using the outer pivot on the wishbone, making it extra wide. Is this a common setup? It's difficult to tell from all the setup sheets as it doesn't cover the width of the insert just the height.
Thanks in advance
Pete
Update: looks like manual for D model has extra wide setting and narrow as kit setting for the M and S model.
Thanks in advance
Pete
take a look on petit for Ben Smith setup at Herts last year as an example. You do need the dirt inserts to achieve the “later” letter settings and depending on what you run, different length driveshafts may be required to retain correct engagement in the drive cup. I think it might be the dirt car UJs in this case.
#588
when you run the wide hub, you run narrower hexes, such as -2, to keep same overall width
#589
Company Representative
if your in North America, I would suggest buying the LD3M, in my opinion this is the best suited car for our market and directly competes with offerings from other manufacturers. If you run 21.5 or 17.5 then just add the factory slipper eliminator and you’re good to go.
#592
That is what I have done. I run 17.5 and will try the slipper but probably change to the slipper eliminator before the Florida Carpet Champs in November.
#594
i have noticed a few people run the graphite chassis from the stock kit on wet astro/low grip tracks..any particular reason they do that?
is it because its lighter so you can get more chassis weights/under lipo weight at the rear of the car or does the chassis generate more grip than the alloy one?
#595
#597
About to pull the trigger on a ld3d kit for low/medium grip outdoor dirt. Aside from arms whats any other parts I should buy for spares?
Also what do you guys recommend for machined pistons? Do 13mm pistons for AE work? Also does anyone know if the ld3d comes with softer springs in the kit or is the only difference the layback tranny/longer cvd’s? Any other option parts I should get? Was going to get brass C block at least.
Where’s the best place to get parts in the US? Amazon’s selection of parts is pretty limited.
Sorry don’t have time to read the whole thread. Thank you.
#598
Edit: You'll probably damage the top plate if you break the bottom bit, so get U8187 as well
#599
it’s the same springs as ld3m so chances are you’ll want to change them out, depending on your conditions. I would suspect the AE machined pistons work, I think Schumacher have some too. Or check out the VRP pistons. Petit RC has some decent setups for most track types.
alloy servo horn always a good shout - the kit one is a bit rubbish unless you superglue it together.
take a look at the v4 ball diff when the v3 kit one is worn out - it’s so much better and longer lasting.
#600
the only real difference is the transmission and the driveshaft length/hub inserts/rear hexes.
317Likes
