Schumacher cougar LD3 >
Like Tree317Likes
Old 08-12-2025 | 12:29 PM
  #586
Originally Posted by Pistol123
Looking at the Manual I assumed the wide and narrow pivot options on the rear hub tied in with the two pivot options on the wishbone - i.e if you are using the wide pivot on the wishbone then the rear hub insert is set with the hole on the outside
How I have looked at a couple of cars running at our track and also how my car was set up when it arrived, the hub insert is with the hole on the inside but still using the outer pivot on the wishbone, making it extra wide. Is this a common setup? It's difficult to tell from all the setup sheets as it doesn't cover the width of the insert just the height.
Thanks in advance
Pete
Update: looks like manual for D model has extra wide setting and narrow as kit setting for the M and S model.
when you run the wide hub, you run narrower hexes, such as -2, to keep same overall width
take a look on petit for Ben Smith setup at Herts last year as an example. You do need the dirt inserts to achieve the “later” letter settings and depending on what you run, different length driveshafts may be required to retain correct engagement in the drive cup. I think it might be the dirt car UJs in this case.
TobyStephenson is offline
Old 08-12-2025 | 12:51 PM
  #587
Thanks!
Here you go:
(Big Picture was here)
I used these and drilled out the rears to 1.8, there also tapered ones available which are yellow.
Rfury is offline
Old 08-12-2025 | 01:51 PM
  #588
Pistol123's Avatar
Thanks, my kit was originally a dirt kit so I have E,F,G & H options along with longer driveshafts. Will take another look at Ben's setup.
Pistol123 is offline
Old 08-13-2025 | 06:50 AM
  #589
Company Representative
Originally Posted by Rfury
I am thinking about getting a LD3S. What are the best bang for buck upgrades for the kit over the base kit?
if your in North America, I would suggest buying the LD3M, in my opinion this is the best suited car for our market and directly competes with offerings from other manufacturers. If you run 21.5 or 17.5 then just add the factory slipper eliminator and you’re good to go.
Korgae is offline
Old 08-13-2025 | 04:58 PM
  #590
I've just picked up a LD3M. Would you verify the part #s I'd need for the Slipper Lockout please?
Rob...
hasty1066 likes this.
Robio is offline
Old 08-13-2025 | 09:27 PM
  #591
Think I answered my own question. Good ole search bar... U8582 ?
Robio is offline
Old 08-15-2025 | 12:13 PM
  #592
That is what I have done. I run 17.5 and will try the slipper but probably change to the slipper eliminator before the Florida Carpet Champs in November.
Rfury is offline
Old 08-18-2025 | 05:40 PM
  #593
Yes that the correct part number for the eliminator.
Robio likes this.
Korgae is offline
Old 08-26-2025 | 08:17 AM
  #594
i have noticed a few people run the graphite chassis from the stock kit on wet astro/low grip tracks..any particular reason they do that?
is it because its lighter so you can get more chassis weights/under lipo weight at the rear of the car or does the chassis generate more grip than the alloy one?
fastboy is offline
Old 08-26-2025 | 08:32 AM
  #595
Brandon11m's Avatar
Carbon chassis tend to have more chassis flex which can help generate a bit more grip from the car and make it easier to drive
Pistol123 likes this.
Brandon11m is offline
Old 09-05-2025 | 10:52 AM
  #596
ChadoSan's Avatar
Taz_S, Rfury and Pistol123 like this.
ChadoSan is offline
Old 09-08-2025 | 10:50 AM
  #597
wydopen's Avatar
Default Ld3d
About to pull the trigger on a ld3d kit for low/medium grip outdoor dirt. Aside from arms whats any other parts I should buy for spares?
Also what do you guys recommend for machined pistons? Do 13mm pistons for AE work? Also does anyone know if the ld3d comes with softer springs in the kit or is the only difference the layback tranny/longer cvd’s? Any other option parts I should get? Was going to get brass C block at least.
Where’s the best place to get parts in the US? Amazon’s selection of parts is pretty limited.
Sorry don’t have time to read the whole thread. Thank you.
wydopen is offline
Old 09-08-2025 | 11:10 AM
  #598
The lower front kickup plate thing will snap in half if you hit something hard enough. Part number U8188.
Edit: You'll probably damage the top plate if you break the bottom bit, so get U8187 as well
wydopen likes this.
BuggyFan21 is offline
Old 09-08-2025 | 12:55 PM
  #599
the only real difference is the transmission and the driveshaft length/hub inserts/rear hexes.
it’s the same springs as ld3m so chances are you’ll want to change them out, depending on your conditions. I would suspect the AE machined pistons work, I think Schumacher have some too. Or check out the VRP pistons. Petit RC has some decent setups for most track types.
alloy servo horn always a good shout - the kit one is a bit rubbish unless you superglue it together.
take a look at the v4 ball diff when the v3 kit one is worn out - it’s so much better and longer lasting.
Old 09-08-2025 | 01:51 PM
  #600
wydopen's Avatar
Thank you
wydopen is offline
